Author: Subject: mot fail. light problem. help needed
nick-york
posted on 23/9/15 at 07:23 PM Reply With Quote
Hi! I've taken my kit for mot today and it failed on some silly little but annoying things. Fog light not working but I'm 99%sure it's just the bulb. But the main beam doesn't come on when it should. In fact main beam doesn't work at all. The annoying thing is that last time I drove in the dark the lights worked perfectly! The fuses are ok. Now I don't think it's that both main beam filaments have blown. I suspect it is something to do with the wiring where it joins to the light / indicator stalk or maybe the stalk mechanism. If it's the mechanism then would it be easier to fit an aftermarket one? It's not Sierra. I think it's escort. Has anybody else had this problem? What's the best solution? Cheers - nick
cliftyhanger
posted on 23/9/15 at 07:32 PM Reply With Quote
First thing is to find what the issue is. Guessing is not helpful.
Well worth checking the bulbs first, easy enough especially if you have a meter (£5 very well spent, I find them essential) Then work your way back.
It is possible you have a relay? if so check that, they do fail. Then back to the switch, check to see if you have current coming out. Then in.....
HowardB
posted on 23/9/15 at 07:41 PM Reply With Quote
I had the exact same problem, turns out that I had cunningly wired my car so that main beam and the fog light only work when the ignition is on,....
hmmmmmm seemed so sensible at the time.
Howard
SteveWalker
posted on 23/9/15 at 08:34 PM Reply With Quote
I've had the stalk "fail" a couple of times. Switching on and off repeatedly has got it sort of working. Doing the same with switch cleaner sprayed in has sorted it out for the next couple of years each time.
Jon Ison
posted on 23/9/15 at 10:18 PM Reply With Quote
Are they on a relay?
snapper
posted on 24/9/15 at 06:22 AM Reply With Quote
Most early Escort and some early Sierra ( square hazard switch version) were full load now relays.
Electrical fault finding, start easy, check fuses, check bulbs, check power to fuses and bulbs
If power to fuse and no power to bulb its in between.
Check switches, usually have connector plugs, if power found at plug it could be the switches, hot wire past switch to headlight feed, bulb comes on its the switch
I eat to survive
I drink to forget
adithorp
posted on 24/9/15 at 06:47 AM Reply With Quote
Don't jump to conclusions. Check the bulds first and whether there's live feed to them.
http://jpsc.org.uk/forum/
nick-york
posted on 24/9/15 at 07:36 PM Reply With Quote
Well I'm very busy with work and everything at moment so decided to try the electrical contact cleaner since I was near motor save. Hey presto!! It's worked! So it was obviously was the switch mechanism on the stalk. If it didn't fix it then next job would of be checking the bulbs, circuits and the relay. Thanks everyone for the helpful advice. Oh put new bulb in fog light and still doesn't work but that wasntt the main problem.
snowy2
posted on 30/9/15 at 08:30 AM Reply With Quote
Modern car column switches are generally not designed to take the full current of the switched load. rather they need relays to do the job ......however they will work fine without relays....the switches just won't last long that's all.
sometimes you are the pigeon, most of the time the statue.
