Author: Subject: Fog light question
nick-york
posted on 24/9/15 at 07:48 PM Reply With Quote
Fog light question
Hi. As you've probably seen in my previous topic my kit failed it's mot but all sorted apart from the fog light problem. It wasn't working. I put new bulb in and realised I actually have two fog lights! One working and the other not even with a new bulb in. Im sure legally you only need one. So could i just put some black tape over the lens as a temporary solution to get it through retestand then sort it afterwards? Ive only few days to get it sorted for a free retest and a sat morning one is what im hoping for. Cheers - nick
cliftyhanger
posted on 24/9/15 at 07:53 PM Reply With Quote
I think you will need to remove it?? at least I would be worried about just using tape.
And which side is working, IIRC it must be central or towards the offside. So if nearside you are stuffed.
You could always bodge on a wire to the working one to join to the non-working. But surely it can only be connections or a damaged wire if the other is OK.
SPYDER
posted on 24/9/15 at 07:58 PM Reply With Quote
If the car is on a Q plate you don't need one at all.
From the manual...
b. Vehicles having a Q plate registration when presented for MOT are to
be treated as follows: For emission purposes only, all these types
are to be considered as vehicles first used before 1 August 1975. For
all other testing purposes they are to be considered as being first
used on 1 January 1971,
Also...
This inspection applies to the one rear fog lamp
which is required to be fitted to the centre or offside
of vehicles first used on or after 1 April 1980.
[Edited on 24/9/15 by SPYDER]
big-vee-twin
posted on 24/9/15 at 08:24 PM Reply With Quote
As a quick fix why not connect the working one to the non working one and disconnect the faulty wiring.
http://www.triangleltd.com
adithorp
posted on 24/9/15 at 08:29 PM Reply With Quote
You only need one but it must be central or o/s. Lot's of tin tops have lenses both sides but only wiring and bulb on the o/s.
http://jpsc.org.uk/forum/
nick-york
posted on 25/9/15 at 07:39 PM Reply With Quote
Well it was the offside one that wasn't working. So I spent an hour and a half getting some wire and connectors and I connected two wires from the working fog light and out to the non working light. A very fiddly job! And it still didn't work! After a lot of messing around I discovered the problem! The faulty light had both wires connected to the same connected on the bulb holder!! I swapped a connecter onto the right part and it worked!!
snowy2
posted on 30/9/15 at 08:19 AM Reply With Quote
Only the O/S fog needs to work. The other does not need to work NOR does it need to be removed from the car if it cannot be made to work.
sometimes you are the pigeon, most of the time the statue.
snowy2
posted on 30/9/15 at 08:22 AM Reply With Quote
Mind you if it were up to me I would make the use of rear fogs illegal tomorrow I see no overall benefit in their use. As most folks switch them on at the slightest hint of mist and won't turn them off when someone is behind them.
