cloudy
posted on 15/10/15 at 08:19 AM |
IVA Rules for Projections in Footwell?
Does anyone know the rules for projection testing in the footwell, fore of the dashboard? Does the 150mm height rule split the space?
It's not hugely clear from the IVA manual or the IVA help sheets...
Thanks,
James
www.warnercars.com
gremlin1234
posted on 15/10/15 at 09:03 AM |
there is a diagram in the iva manual that makes it clear that in this space below 150mm is tested with the 100mm sphere, and above using 165mm
sphere.
diagram is annex 2 section 12 of the manual
loggyboy
posted on 15/10/15 at 09:04 AM |
Mistral Motorsport
cloudy
posted on 15/10/15 at 09:07 AM |
That in itself makes sense - but this seems to contradict it, by showing anything above the 150 line is not tested. There's also a dashed line
on Annex 2 describing the bottom of dash, but it doesn't mention if that changes the test! Might be missing something here!
https://www.gov.uk/government/publications/individual-vehicle-approval-iva-for-cars-help-to-get-a-pass/individual-vehicle-approval-iva-for-cars-help-t
o-get-a-pass
www.warnercars.com
loggyboy
posted on 15/10/15 at 09:14 AM |
Work to the more lenient guidance and argue should it fail. If its in black and white (or colour in this case!) they cant argue.
Mistral Motorsport
Slimy38
posted on 15/10/15 at 09:34 AM |
I sort of disagree. I would work to the latest version of the iva manual, any diagrams elsewhere (even if its still on the dvla website) should be
considered out of date. I would expect the tester to consider the manual as being gospel.
loggyboy
posted on 15/10/15 at 10:24 AM |
Manual is older than website though!
Mistral Motorsport
Slimy38
posted on 15/10/15 at 10:41 AM |
Then again, looking at the pictures I 'think' they are saying the same thing. The area above 150mm is tested to S12 RS.1, which I assume
is the 165mm sphere. The blue areas match up with the exempt area (behind the seats) and whatever is in front of the steering wheel. The dashed line
(which in both diagrams is 250mm backwards of the seat cushion) also adds up as being exempt in both diagrams.
loggyboy
posted on 15/10/15 at 10:49 AM |
But manual diagrams points to an objects over 150 line that is shown behind the das and says they are accessed with 165 sphere, where as blue shaded
area behind dash on the 'guide' states its not accessed! I can understand Cloudys confusion!
[Edited on 15-10-15 by loggyboy]
Mistral Motorsport
Slimy38
posted on 15/10/15 at 11:04 AM |
Oh yeah, now I follow. I had just assumed that the blue area is the bit behind the dash, which the IVA manual says is not tested (it's not in
that drawing but I'm 99% sure it's in the accompanying text).
gremlin1234
posted on 15/10/15 at 11:59 AM |
remember the iva is a set of minimum requirements,
just imagine your knee hitting something under the dash, so try to make everything round there satisfy the 100mm sphere requirements.
