Author: Subject: Ignition on = Stalk controlled lights off.
Staple balls
posted on 21/10/15 at 07:47 PM Reply With Quote
I bought one of these here stalks
Which has instructions in the catalogue with the pinout:
(fly)Green: Flasher Relay
(fly)Green/Red: Flasher Relay
Twin Green: Ign +
Brown: Perm +
Purple: + to Horn
Green/Red: Left Ind
Green/White: Right Ind
Blue: Feed from HL switch
Blue/Red: Dip +
Blue/White: Main +
I have tied it to a premier loom (instructions here) like so:
Flasher Relay: Black/Yellow
Flasher Relay: White/Back
Ign +: Red/Black
Perm +: Red/Blue
+ to Horn: (not used)
Left Ind: Black/white
Right Ind: Black/Green
Feed from HL switch: (batt + for testings)
Dip +: Brown/Yellow
Main +: Brown/White
Anyway, it all works fine until I turn the key at all, so I assume I've done something stupid. Any ideas before I fall down a rabbit hole?
cliftyhanger
posted on 22/10/15 at 06:17 AM Reply With Quote
Is the perm live you connected the (brown) wire to actually staying live?
Staple balls
posted on 22/10/15 at 06:54 AM Reply With Quote
Good point well presented.
Staple balls
posted on 23/10/15 at 11:22 AM Reply With Quote
Turns out the issue was my relays were set for switched earth, instead of switched live.
