Author: Subject: What Engines will work with Ford Type 9 gearbox
Antnicuk
posted on 25/10/15 at 06:54 PM Reply With Quote
I am looking at a car with a 2.0l pinto and type 9 box from a sierra. I want to replace the engine for something with more power and wondered if there are option for keeping the type 9. This will also depend on the power and torque that a type 9 will take for track use in a 700kg car.
It would probably need to be 2.0L turbo if a 4 cylinder 2.0L as i want in excess of 250 bhp. I have seen a few saab engines and know that people have used these in a rwd set up and they are bullet proof. Not sure what box they are using but the type 9 seem to fit the red top engine
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
Daf
posted on 25/10/15 at 07:09 PM Reply With Quote
I doubt very much a standard type 9 will handle 250hp - generally from what I've read 200 is about your limit before things start to go wrong.
Antnicuk
posted on 25/10/15 at 07:17 PM Reply With Quote
thanks, i thought there may be a fairly low limit, shame, would have made any conversion a bit cheaper and easier
big-vee-twin
posted on 25/10/15 at 07:19 PM Reply With Quote
Type 9 goes to about 200, then you need a heavy duty upgrade/rebuild.
http://www.triangleltd.com
Daf
posted on 25/10/15 at 07:23 PM Reply With Quote
Plenty of engine choices though, with the removable bell housing you can buy a replacment to mate it to loads of options. I got my bellhousing from here:
http://www.rwdmotorsport.com/
great people to deal with
Ugg10
posted on 25/10/15 at 07:30 PM Reply With Quote
One of the favourite turbo conversion would be the Vauxhall calibra turbo (XELET?) with a new bell housing. But if you want 250hp+ then I would be looking at a s14 200sx engine that comes with a rwd gearbox already. As for the type 9, stock will take around 150hp, the quaife clubman is rated at 190hp and HD version 240hp (see bgh website) but you are looking at 1500+ which will pay for the 200sx, all mods and a decent tuning session.
Also be aware that a diff and brake update may well be needed as you will be doubling the power. Don't forget to budget for new mounts, intercooler and exhaust.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
Ben_Copeland
posted on 25/10/15 at 07:39 PM Reply With Quote
I run a standard type 9 with 272bhp and 309ftlb torque. 2.0L Vauxhall turbo with alloy bel housing. If you want to run the type 9 do it!!! Mines done over a year and has been fine.
It's not power that kills gearboxes it's torque and the torque is related to the weight of the vehicle. Less weight more torque it can take from the engine. The wheels spin before the gearbox gets too stressed
[Edited on 25/10/15 by Ben_Copeland]
Ben
Locost Map on Google Maps
Enter Your Details Here
View User's Profile View All Posts By User U2U Member   Ben_Copeland 's Aim This User Has MSN Messenger
Daf
posted on 25/10/15 at 07:41 PM Reply With Quote
I bet that's fun, I'm impressed the type 9 is coping with that! Did you rebuild the box before using it? How much does your car weigh?
Antnicuk
thanks all, it has confirmed my suspicions. I may go back to rotary, rx8 have a nice 6 speed box but it is quite wide and not sure if it would fit in the tunnel, my cousins Tiger avon has it fitted but it was a squeeze. Mine is a Super six, not sure if it is wider or narrower than the avon
jimgiblett
posted on 25/10/15 at 10:26 PM Reply With Quote
if you decide to sell the type 9 let me know as I have a mate looking for one for Marlin to convert it to 5sp
Jim
Ben_Copeland
posted on 26/10/15 at 03:38 PM Reply With Quote
Nope. It's a v6 box but they are same strength apparently. It's straight out of someone's garage. 660kg plus me
You can run a RX8 box with an adapter plate for most engines or if you go Vauxhall engine a omega box is plenty strong enough. There's loads of choices
[Edited on 26/10/15 by Ben_Copeland]
Ben
Ben_Copeland
posted on 26/10/15 at 03:39 PM Reply With Quote
You can use that RX8 5/6 speed box on a lot of engines now.
Ben
posted on 26/10/15 at 03:44 PM Reply With Quote
Focus RS mk1 fits a type 9 as does any previous zetec engine.
Can easily be tuned to 350bhp.
