Author: Subject: f#*@king Paint.
Craig81
posted on 12/12/04 at 11:47 AM Reply With Quote
f#*@king Paint.
Hi all,
After only 300miles in my locost, the 2pack paint on the rear arches has stone chipped to buggery!!! They are going to have to be respayed before the spring as they look horrible.
Does anybody know if i can get a type of protective film to cover the paint once its respayed!!!
craig
I love speed :-P
posted on 12/12/04 at 03:10 PM Reply With Quote
i think u can use something called rotor tape? anyway its used on helicopter blades to stop them chipping
[Edited on 12/12/2004 by I love speed :-P]
Don't Steal
The Government doesn’t like the competition
Wadders
posted on 12/12/04 at 03:31 PM Reply With Quote
Best to fit arch protectors, ally or carbon. before fitting them i smashed holes in both rear arches with stones thrown up from the front tyres. Also fitted clear flaps to the bottom of the front cycle wings which made a huge difference.
MK do carbon look raer arch savers.
Originally posted by Craig81
Hi all,
craig
Northy
posted on 12/12/04 at 04:55 PM Reply With Quote
Wadders, where did you get clear mub flaps? Or did you craft them from something?
Graham
Viper
posted on 12/12/04 at 06:41 PM Reply With Quote
There is a product its called Armourfend, take a look at the front end of most TVR's....
Tim
DaveFJ
posted on 14/12/04 at 12:26 PM Reply With Quote
I would deffinately NOT recommend helicopter blade tape. I have extensive experiance of this stuff (as a former helicopter engineer). It will look... Ok when it first goes on but after a couple of weeks it will look like total shit, it will go opaque and start to yellow. also it is almost impossible to get all the tiny air bubbles out. Abolute bastard to remove as well
Dave
Mix
posted on 14/12/04 at 02:35 PM Reply With Quote
I have to dissagree Protofj. Blade tape nowadays does not discolour and air bubbles can be easily avoided if applied correctly. You are however perfectly correct in saying it sticks well.
It is also virtually impervious to minor impacts.
Minor drawback is the thickness, it's about 0.7mm thick, the stuff Lotus use is about half that. I'm guessing that's probably the same stufff Viper was refering to.
Mick
DaveFJ
posted on 14/12/04 at 02:39 PM Reply With Quote
Mybe you have access to some 'new' stuff that that is not available to the military then ?
Dave
Mix
posted on 14/12/04 at 02:49 PM Reply With Quote
It was a bit of an 'eye opener' when I left the forces. The civil industry , (which up until then I had considered to be lagging behind) was actually streets ahead in a lot of aspects.
Mick
stephen_gusterson
posted on 14/12/04 at 05:28 PM Reply With Quote
i dont iamgine it matters too much what colour you paint a missile, does it
atb
steve
mind you, pink would look a bit duff on a tornado....
Mark Allanson
posted on 14/12/04 at 08:31 PM Reply With Quote
I think you need stonechip vinyl, available from bodyshop suppliers. It is the same stuff you see on the rear quarters of Porsche 944's and the like. It can be overpainted and does the job a treat.
I looks just like thick rubbery cellotape and comes in rolls upto a max of 300mm. Warm it with a heatgun, and you will not get any air bubbles especially if you work from the centre and work outwards. You can also use soapy water to float it into position, and then squeegie the water away with a filler spreader.
Avoneer
posted on 14/12/04 at 09:02 PM Reply With Quote
What's wrong with the bit of ali or stainless riveted on solution?
Pat...
Craig81
posted on 15/12/04 at 06:48 PM Reply With Quote
i have got some ali protectors on there, all the chipps are appearing all around them!!!!!
chunkielad
posted on 9/1/05 at 11:26 PM Reply With Quote
Speak to LIZ at KPMF direct (vinyl supplier to the sign industry) http://www.kpmfdirect.co.uk/
and tell her Craig from Warrior Signs sent you. Ask her for some VWS. It's a vehicle wrap vinyl that comes in clear (often printed on before applying to add images to vehicles). It's quite thick so will protect against most stone chips and will (with a bit of heat and practise) cover the whole car if you want to.
silex
posted on 10/1/05 at 01:04 PM Reply With Quote
Which type of 2-pack paint did you use ?
Murphy's 2 laws
1. If it can go wrong it will
2. In case of emergency - refer to rule 1.
DarrenW
posted on 11/1/05 at 10:40 AM Reply With Quote
In my BMW days a lot of the lads doing track days in the family cars used something like armourfend to protect from chips. If i remember correctly it was marketed towards the track day crowd. I think there are several products available. I do about 25 - 30K miles a year in my Mondeo and fitted the Ford bonnet protector. Clear film, use spray of sqeezy on bonnet first. Once aligned removed bubbles. Tight corners warmed up with hair drier first. With practice can look 'almost' invisible. After a year i cant see any chips through to the bonnet.
What is the best stuff to use as mud guard on cycle wings?
Darren.
Marcus
posted on 11/1/05 at 09:09 PM Reply With Quote
Darren
Re mudflap material, I'm in the process of fitting some made from clear anti slip table mats I found in a yacht chandlers. Exactly the right size and nearly invisible (when clean!!)
Marcus
Marcus
Because kits are for girls!!
