Author: Subject: IVA Brake Dust Shields/Back plates
maccmike
posted on 13/11/15 at 04:44 PM Reply With Quote
Are they needed?
[Edited on 13/11/15 by maccmike]
loggyboy
posted on 13/11/15 at 04:53 PM Reply With Quote
Cant think what they would be tested for?
Mistral Motorsport
chris68
posted on 13/11/15 at 05:14 PM Reply With Quote
I hope not! Mine had rust holes in them which was mirrored underneath the rest of the MX5. Can't see why they would be required for IVA, guess they are supposed to stop too much crud getting around the brake gear but I assume this will depend how exposed the brakes will be in whatever set up they are used in.
Not using them on the SR2 and from the SR2 builds I have seen thet are on the road most seem to be missing.
posted on 13/11/15 at 05:56 PM Reply With Quote
Their real function is as splash shields. ---
A bit of motoring trivia they were developed by Girling engineers in the late 1950's when developing brakes with the Rootes Group for the Minx based dart shaped Sunbeam Alpine. Rootes had both Lockheed and Girling biding for the contract but Rootes found both systems were suffering from excessive brake pad wear Girling engineers made a breakthrough and discovered the excessive wear only occured a in wet weather and cured the problem with the splash shields.
Girling won the contract and supplied the brakes for the Alpine and the big Humbers but strangely 4 years later the contract for the disk brakes for the higher volume models in the Minx range went to Lockheed.
maccmike
posted on 13/11/15 at 06:55 PM Reply With Quote
Good trivia.
Thanks guys
adithorp
posted on 13/11/15 at 08:50 PM Reply With Quote
Originally posted by maccmike
Good trivia.
Thanks guys
But the answer is no, not required.
http://jpsc.org.uk/forum/
