Author: Subject: In line fuel pump pre filter
Mikef
posted on 1/12/15 at 10:59 AM Reply With Quote
Morning All.
Knocking up a new system using an in line pump. The pump has a 12 mm inlet, which is what I have put in the tank and an 8mm outlet. The issue I am having is finding a pre high flow / low pressure filter that has 12mm push fit at both ends. There are one or two US ones around but silly money . Any thoughts on please.
beaver34
posted on 1/12/15 at 11:09 AM Reply With Quote
ford cosworth item
that what i use with the correct aeroquip adaptors
i work for Ford we have them on the shlef if you do want to go down that route, around £20
they look like this
http://www.burtonpower.com/motorcraft-injection-fuel-filter-ford-sierra-sapphire-cosworth-efg84.html
Paul Turner
posted on 1/12/15 at 11:41 AM Reply With Quote
I used a Sytec Bullet Filter http://www.glencoeltd.co.uk/sytec-fuel-filters-swirl-pots-water-separators/sytec-motorsport-fuel-filters-bullet/bullet-fuel-filter-1-4npt-female-red/ which is available with an assortment of fitting including 12mm. More expensive than an off the shelf filter but the elements are easy to replace and are cheap, under a fiver.
cliftyhanger
posted on 1/12/15 at 11:42 AM Reply With Quote
or an alternative
SYTEC MOTORSPORT FUEL INJECTION PUMP PRE FILTER CHOICE OF 8MM 12MM 15MM -6 -8 HN
Mikef
posted on 1/12/15 at 11:46 AM Reply With Quote
Big Thanks for this. Had seen the Sytec , did not realise they went up to 12 mm , will also have a look at the Cosworth.
ash_hammond
posted on 2/12/15 at 04:31 PM Reply With Quote
I got one of these with 12mm barbs on, cheaper than the rest.
IN-LINE FUEL FILTER Petrol & Diesel - Small/Large/Long 6mm/8mm/10mm/12mm Hose
.: www.mac1motorsports.co.uk | www.m1moc.com :.
DW100
posted on 2/12/15 at 04:46 PM Reply With Quote
The SYTEC one looks very much like the OE Rover 200/400 one with some adapters.
like this;
Rover, Lotus, Jaguar, Land Rover (1985 on) *New* Fuel Filter Fram G3727
[Edited on 2/12/15 by DW100]
