Author: Subject: Engine oil lubrication system
bikecarbfred
posted on 7/12/15 at 08:35 PM Reply With Quote
We have an engine block. No squirters for cylinders walls and no pressurized oil feed for the piston pin. Everything relies on splish splash.
The crankshaft sits above the oil sump. When oil level is to the max level, the centre of the crank sits 7cm above the oil. When the crank rotates the big fins on the crankshaft would just skim or not even that along the oil when oil is at max level.
How can you get splish splash from that? Someone told me that it is like a hurricance down there.
The only way I can see them catching and splishing everything is when the car is being driven and oil in the sump is going left to fight back and forth. But what happens when the car is sat idle.
I am sure i'm missing something but I always thought the cranks splash into the oil in the sump
Nickp
posted on 7/12/15 at 10:18 PM Reply With Quote
Oil will be squirting out of each big end bearing and 'splishy splashing' around
Dusty
posted on 8/12/15 at 12:01 AM Reply With Quote
' I always thought the cranks splash into the oil in the sump '
Cranks do not and must not do this. It would thrash the oil to a foam and all the rotating bearings would end up being fed mostly air.
bi22le
posted on 8/12/15 at 08:23 AM Reply With Quote
Oil will be going on every surface. It will be splashing up the sides and all sorts.
In my head i have the idea that modern engines dont allow the balance bells to hit the pan oil as it uses energy and reduces performance. I would say that (depending on engine designer) trust what they have done.
Regarding hurricain down there comment. I would say so. Oil mist, 5k RPM of rotating metal and being thrown around, there wont be a dry part.
Please read my ring story:
Nickp
posted on 8/12/15 at 08:41 AM Reply With Quote
Agreed, it'll be wetter than an otters pocket in there
snapper
posted on 8/12/15 at 10:21 AM Reply With Quote
Notching the rod is an option
Used when fitting Cosworth rods to a Pinto without the Cosworth pump and spray bar
I eat to survive
I drink to forget
DW100
posted on 8/12/15 at 10:38 AM Reply With Quote
The normal way is that the oil pump pumps oil up to the main bearings, from there it travels through drillings inside the crank to the big ends and as can be seen on the top rod in the picture above through drilled holes to spray at the bottom of the piston. Neither the main bearing or the big ends are sealed at the side, so oil spills from the sides and is thrown about by the rotational forces of the crank.
The crank should not be in the oil. I once heard David Vizard describe it as the crank belly flopping onto the oil at 7000 RPM. You could imagine the forces involved breaking the crank.
Theshed
posted on 8/12/15 at 11:00 AM Reply With Quote
The howling gale in the sump is not just caused by the crank but also the pistons moving up and down shifting the air around. It actually wastes a lot of power hence folk knife edging the lobes of the crank and radiusing the block to improve the aerodynamics (that is hardcore!). Use of scavange pumps on a dry sump system also improves power output for the same reason - less air to move around if you are running a vacuum.
In a moment somebody running an Austin 7 engine will pop up to talk about the spit and hope crank lubrication system....
mcerd1
posted on 8/12/15 at 12:58 PM Reply With Quote
^^ but in that case its just easier to fit a cossie 2wd pump and spray bar
bottom end built :D
bottom end built :D
bikecarbfred
posted on 8/12/15 at 10:17 PM Reply With Quote
So from what I learnt is that in my type of engine it is imperative that the oil feeds in the crank and also the oil feeds in the block feeding into the crank bearings are totally free because this is the only way I will get the splish splash (through the side of the main bearing - squirting and spiraling like a catherine wheel firework effect).
So with these blocked not only will it ruin the crank but can also ruin the cylinder walls. So a total fail of the engine in one go.
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
Building: Run 2 ltr Black Top in single seater race car.
posted on 8/12/15 at 10:47 PM Reply With Quote
Originally posted by Theshed[/i
In a moment somebody running an Austin 7 engine will pop up to talk about the spit and hope crank lubrication system.... [/quote
or those of us old enough to remember the old stationary engines, Petter, Lister etc with the old quill dippers, but they always seemed to work..... I just tried to post a picture of a dry sump pan that we make for modern engines to try to illustrate, but failed. It went into the forum header but that was it.....
Paul Turner
posted on 9/12/15 at 10:16 AM Reply With Quote
That applies to every engine made. When assembled all the parts must be scrupulously clean and then the correct grade of oil used and changed regularly. Providing that is done the whole engine should be lubricated as intended.
