Author: Subject: H BEAM Rods
bikecarbfred
posted on 10/12/15 at 04:22 PM Reply With Quote
H BEAM Rods
I've been offered a set of h beam conrods that are already made to size -ISH.
Small end width.: I measured 19.98mm on my oem conrods.
The new h beam size show 19.9mm on ebay.
The 19.98 I measured with a electrical readying ruler. I pushed hard on it aswell.
Can 0.8mm make a difference?
snapper
posted on 10/12/15 at 04:51 PM Reply With Quote
Mostly yes
Is the gudgon pin interference fit i.e. Fixed in he rod
Or
Loose got with cyclops in the piston
You can team a smaller little end bush to take a larger gudgon pin but you should not fit a loose gudgon pin or you get little end knock
You need to measure with proper accurate internal and external gauges to a thou of an inch do pin in piston and pin in rod little end are within tolerance
I eat to survive
I drink to forget
russbost
posted on 10/12/15 at 05:27 PM Reply With Quote
Originally posted by snapper
Mostly yes
Or
Don't you just love predictive text!
bikecarbfred
posted on 10/12/15 at 06:09 PM Reply With Quote
lol.
I don't think I explained it well.
The gudgeon piin will be same size with correct bush.
The small end size sliding into the piston and the pin going straight through.
It's the width of the rod when it slides into the piston which could be half a mm narrower.
But I suppose the force is going up and down.
edit: getting confused now. 19.9mm to 19.98mm
[Edited on 10/12/15 by bikecarbfred]
snapper
posted on 10/12/15 at 06:42 PM Reply With Quote
Your fine with that size
I eat to survive
I drink to forget
snapper
posted on 10/12/15 at 06:50 PM Reply With Quote
Russ I think you'll find that the predictive text version is with 10% of what it should be and therefore completely within the spelling and grammar specifications as advertised on my other sites.
Whilst we endeavour to be as accurate as possible due to manufacturing tolerances my post may be considered utter b**|+€ks
I eat to survive
I drink to forget
Volvorsport
posted on 11/12/15 at 06:45 PM Reply With Quote
Depending on whether they are piston steered or crank steered
www.dbsmotorsport.co.uk
getting dirty under a bus
posted on 16/12/15 at 12:03 PM Reply With Quote
Surely you mean 0.08mm?
bikecarbfred
posted on 16/12/15 at 03:14 PM Reply With Quote
yes. 0.08 sorry. - I got them in the end and they fit good.
bikecarbfred
posted on 29/12/15 at 08:05 PM Reply With Quote
i got the small end bearings off with ease but only from 3 of the 4 conrods.
the 4th one it moved 4mm then got stuck and i dont see why. any clues?
