Author: Subject: Alternative to Sierra stalks
carlknight1982
posted on 28/12/15 at 09:06 PM Reply With Quote
Anyone converted from Sierra stalks to something newer? My indicator stalk is playing up and I figured now could be a good time to change them
Logic will get you from a A to B
Imagination will take you everywhere.
posted on 28/12/15 at 09:39 PM Reply With Quote
I changed mine to one off a Toyota corrola. Everything on the stalk, lights fog indicators horn all on one stalk.
Adamirish
posted on 28/12/15 at 10:30 PM Reply With Quote
I've moved everything onto savage switches and a toggle switch for the indicators. Looks nice but took a while to get used to where everything is now.
MK Indy 1700 Xflow
Rosco86
posted on 29/12/15 at 08:41 AM Reply With Quote
Anygood to you? http://www.locostbuilders.co.uk/viewthread.php?tid=200750
My Build Thread
carlknight1982
posted on 30/12/15 at 03:06 PM Reply With Quote
Afraid not
redscamp
posted on 19/1/16 at 12:46 AM Reply With Quote
how about berlingo mk1?
horn lights fog on left stalk
wash and wipe on right stalk
Smoking Frog
posted on 19/1/16 at 09:56 AM Reply With Quote
I did try another stalk (Renault) but it didn't fit well on the column and wouldn't cancel the turn signal. So used the Sierra one, dismantled, cleaned and lubricated, fiddly but not impossible.
The Black Flash
posted on 21/1/16 at 09:31 PM Reply With Quote
I used pug 106 ones after seeing them used on another build diary. Took an evening to work out the pins, but otherwise easy enough. Just a ally bracket to attach it to the sierra column.
posted on 22/1/16 at 10:18 AM Reply With Quote
On my MK Indy I used the donor Sierra stalks and wired the horn via a relay to the washer button on one of the stalks - worked fine and looked good (passed SVA as well). Using different stalks might require a column change to accommodate.
posted on 22/1/16 at 10:20 AM Reply With Quote
May also be worth contacting a kit maker for parts if you need them?
