Author: Subject: 2 number MT75 gearboxes
terryathome
posted on 9/1/16 at 05:35 PM Reply With Quote
Number 1 gearbox is Steve Livesey (Westfield Lancs AO) old gearbox and works fine, he only changed it as it had the dreaded rattle when foot off the clutch with engine idling which happens to many a car. £80
Number 2 gearbox is mine but sometimes jumps out of 4th gear and has the rattle same as above. So with this in mind box is being sold for £50
Both gearboxes are the Granada MT75 gearbox which puts the starter motor on the drivers side which is on the opposite side to the exhaust on a 1.8 Silvertop and 2.0 Blacktop Zetec engine. They also hydraulic clutch release. I also believe that they are the diesel MT75 gearboxes which have the slightly different ratios to the petrol models but can't confirm that at the moment.
Both gearboxes are bear with no quickshift or clutch release bearing as will be selling these separately.
Collection only due to weight
Will get some pics ASAP, watch this space.
Terry
