Author: Subject: Slightly OT: Defender static roof load
PSpirine
posted on 12/1/16 at 02:12 PM Reply With Quote
Bit of an odd one...
What do we think the static roof load capacity of a 110 Defender would be?
The reason I ask is we're thinking of creating a seating/viewing platform on the roof for summer camping and events, so would want it to hold ~6 people on it.
Would obviously be on a 10 (or so) point mounted roof rack, not on the roof skin!!
In my head I'd be surprised if it wouldn't hold over a tonne in complete safety, but what's the LC consensus?
Obviously this is for stationary condition on level ground only, hence the question, as most roof load discussions are based around driving limitations, which I suspect would max out due to stability long before the structure becomes an issue...
posted on 12/1/16 at 02:26 PM Reply With Quote
I'd imagine an LR dealer would be able to give you a figure.
The issue I see is the moving load as people get themselves up and down.
I once went on an elephant ride. As a fit and able person I did not see any great issue with this, but I had to really hold on to avoid being thrown off.
hizzi
posted on 12/1/16 at 02:29 PM Reply With Quote
I'm sure it's 100kg legally but with a full roof rack you will be fine had four on deck chairs on mine no problem , not very stable though depending on your suspension
Like everything defender it will do more than the book by a long way
HowardB
posted on 12/1/16 at 02:35 PM Reply With Quote
there are roof rack systems for the LR that go beyond the gutter, and esp in the case of a full length extension over the bonnet, the load can be taken directly to the chassis.
I am constantly surprised by the (ab)use that LR are put to,..
hth
Howard
Charlie_Zetec
posted on 12/1/16 at 02:41 PM Reply With Quote
Just remember that even when the load is spread over 10-or-so point mounted roof rack, it's still only connected to the flimsy lip of the roof, in turn connected to the ali bodywork via a dozen or so bolts. You've probably already seen the roof tents that are designed to take 2 people (there is an advised maximum weight limit), which bolt onto roof racks as well, so two could be achievable for a full-length rack on a 90 or 110.
Better option, in my opinion, is not to loo at ordinary roof racks but the extended ones that start in front of the cab area and mount onto the top of the bumper on the chassis rail, and rear crossmember at the rear, as well as the roof gutter. More expensive, but I'd feel a lot happier with that weight distribution.
PSpirine
posted on 12/1/16 at 02:42 PM Reply With Quote
Thanks guys
The 100kg/dealer number is always for a driven condition, and is (at least on Land Rovers) always limited by stability rather than roof crush.
Wouldn't build a rack that goes down to chassis in front of bonnet (as that would involve more welding than my kit car chassis!! ), but sufficiently mounted all around the roof should do the trick!
Charlie_Zetec
posted on 12/1/16 at 03:04 PM Reply With Quote
Originally posted by PSpirine
Thanks guys
THIS is what I was talking about; quite common for those carrying longer loads that are prone to flex, so no major work.
But I also noticed this slight variation of the design where it could mount to the bulkhead or bulkhead/windscreen mounting bracket. Both would offer increased (better) weight distribution.
HowardB
posted on 12/1/16 at 03:33 PM Reply With Quote
Thanks guys
As above, it has legs that bolt to the front bumper mounting - no welding required, and struts that go to where the windscreen hinge points used to be. I have seen several 100kg come off these after a long trek to Iceland, quite often 2 stood on the roof to load/unload.
I (may) have transported a strumech versatower on one before,.... 350kg- ish
hth
Howard
gremlin1234
posted on 12/1/16 at 10:23 PM Reply With Quote
I think I would add same jacks/ axle stands / other support at ground level, something like the rear legs you get on trailers
