Author: Subject: 2.0 duratec up grade
maximus1
posted on 23/1/16 at 09:02 PM Reply With Quote
Been offerd a 2.0 duratec 67k ecu and keys for £650 is that good ?
What's the process for upgrade from pinto I'm not after a race machine just
Fast enough and reliable. What the best way to sort the fuel side out thanks in advance
For any help.
big-vee-twin
posted on 23/1/16 at 09:10 PM Reply With Quote
Duratec from Pinto is straightforward having the exhaust on the same side, you can rework the header to fit.
You can use the type 9 but will need a bell housing which are not cheap.
Lowered sump which are not cheap.
But you can go with carbs, bike carbs or fuel injection either has been done.
I paid £275 for mine with 22k miles on it.
[Edited on 23/1/16 by big-vee-twin]
http://www.triangleltd.com
posted on 23/1/16 at 09:40 PM Reply With Quote
That's not cheap, you can get a whole car for far less with everything you need and sell on the parts to get the motor for nothing!
davidimurray
posted on 23/1/16 at 10:16 PM Reply With Quote
Lots of info on my swap here - http://www.locostbuilders.co.uk/viewthread.php?tid=192871
Realistically a cheap ugrade will be £1k plus
I paid £120 for an engine with 80k on it.
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
