Author: Subject: Passat / A4 Drive shafts
dan8400
posted on 24/1/16 at 08:10 PM Reply With Quote
Hi everyone
I am planning a midi build and wanted to use a Passat / A4 Engine and gearbox (not going BEC) and I wondered if the front / rear drive shafts are the same on a 4wd version. Also, are the front / rear wheel bearings interchangeable? Not sure how I am doing brakes / handbrake etc, so some basic knowledge on the components may help me
Dan
Hey - That's Journey!!!
ian locostzx9rc2
posted on 24/1/16 at 08:17 PM Reply With Quote
In my experience there different front and rear both driveshafts and wheel bearings .
dan8400
posted on 24/1/16 at 08:19 PM Reply With Quote
Ok, thanks for the heads up. And such a quick reply too
Dan
posted on 25/1/16 at 08:53 AM Reply With Quote
I wouldn't swear to it, but be fairly certain that front/rear drive shafts are different due to the different F/R differentials.
What setup do you have in mind - being familiar with a FWD Audi A6, I do know the gearbox/differential was quite long. If you're planning a RWD setup it could take some hiding to get the gearbox covered up. Might be an aesthetic challenge for you.
On the + side, parts should be readily available and relatively cheap to buy.
dan8400
posted on 25/1/16 at 08:58 AM Reply With Quote
Hi Nick,
I am thinking either Passat/A4 / Audi 80 engine and transaxle. I include the 80 due to it being pre '95 for IVA. Although if I get a complete car I can figure out wiring, cat etc.
I have a single seater chassis that finishes at the roll bar. So I can make my own rear end. BEC is out of the question mainly due to cost
Dan
posted on 25/1/16 at 09:23 AM Reply With Quote
OK - understand now!
Not sure the engine and gearbox lend themselves to being structural parts if you need them to be though.
dan8400
posted on 25/1/16 at 09:46 AM Reply With Quote
Hi
Not planning on using it as structure. Will surround the engine/box with a frame. Will be much easier even if it's not as pretty
Dan
posted on 25/1/16 at 10:12 AM Reply With Quote
OK - makes sense so you can integrate mounting points etc.
posted on 25/1/16 at 12:08 PM Reply With Quote
Good plan, I would go with a V8 engine though.
