Author: Subject: Zetec thermostat housing - dimensions?
Rena
posted on 15/2/16 at 08:40 AM Reply With Quote
I will change from Raceline water rail to original thermostat housing, but I donīt know if there are room for it.
Have gooogled to get the dimensions of the original housing, but canīt find it. Can anyone help me with the dimensions?
loggyboy
posted on 15/2/16 at 09:51 AM Reply With Quote
Cant offer dims, but can offer this picture which might give a half decent idea of scale.
[Edited on 15-2-16 by loggyboy]
Mistral Motorsport
GRBBONGO
posted on 15/2/16 at 10:41 PM Reply With Quote
Hi
I've just posted a reply on the other raceline water rail thread. Take a look at the pics I put on another thread recently which shows the correct way to plumb it in. I also went to use the standard housing but for what ever reason was too tight against the bulkhead so bought a raceline water rail from someone off here I think.
It works a treat and have had no problems at all.
Good luck sorting it either way but don't lose faith in the water rail because of people having a few issues with it.
I must admit I was also in two minds whether to go for one or not but found this really good article by someone who had explained why people had been having problems and just followed his instructions to the letter and the rest is history. 700 miles so far, temp comes up fairly quick from cold and sits around 90 degrees while fan cuts in and out. Well happy with it and looks sexy too. Take a look at the pics!
Rena
posted on 16/2/16 at 06:54 AM Reply With Quote
Originally posted by GRBBONGO
Hi
Thansk for your support! I measured my chassis yesterday and found out there are no space for the original housing. So, I have to give the Raceline rail a try otherwise I will buy the retro ford one. It should work better than raceline I hope.
Just a couple of questions. Which thermostat are you using? With or without the bypass-valve? Drilled holes in the rim? Which diameter?
Snuggs
posted on 16/2/16 at 08:12 AM Reply With Quote
I fitted one of these.
Water rail linky
Very well made and keeps the thermostat where it should be.
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
GRBBONGO
posted on 16/2/16 at 09:28 AM Reply With Quote
I think my thermostat is rated at 92 and does have a small 2mm hole on the outer edge. I don't think I have a bypass valve fitted?
GRBBONGO
posted on 16/2/16 at 09:32 AM Reply With Quote
Hi Snuggs, nice looking bit of kit. Which I could of found that one when looking for one. How much do they cost do you know?
Guess I should look at the link before asking this doh!
Rena
posted on 16/2/16 at 09:52 AM Reply With Quote
Ok - thanks!
Rena
posted on 16/2/16 at 09:53 AM Reply With Quote
Water rail linky
Nice piece, but I would like to have the rail on the other side because I will use a Polo radiator with inlet and outlet on the same side.
Paul Turner
posted on 16/2/16 at 10:32 AM Reply With Quote
These are what you need if there is insufficient room for a standard housing.
http://www.retro-ford.co.uk/shop/content/zetec-water-manifold-z008
It places the stat in the correct place and the hose runs down the exhaust side. Not sure if it has the correct bypass though.
I think the one below does have a bypass and is no more expensive. It also puts the stat in the correct place and is probably better quality.
http://www.dunnellengines.com/zetec_components.php?partno=RMP2052
I have used neither, a good old Orion alloy one works for me. No space issues.
Rena
posted on 16/2/16 at 10:36 AM Reply With Quote
Yes, the retro ford looks nice and from what I have heard, works well.
The Dunnell one, costs incl install kit Ģ250 + VAT.
I will give my raceline rail one more try, I think.....
Rena
posted on 16/2/16 at 10:39 AM Reply With Quote
I have found out itīs difficult to find a Orion alloy one, but could you maybe give me the dimensions?
HowardB
posted on 16/2/16 at 10:44 AM Reply With Quote
I can vouch for the Dunnell one,. it's a great bit of kit
Howard
Paul Turner
posted on 16/2/16 at 11:07 AM Reply With Quote
Car buried at the moment but here is a photo that should give you a bit of a clue regarding size.
Its the alloy one.
Rena
posted on 16/2/16 at 11:34 AM Reply With Quote
Its the alloy one.
Thanks! Looks a bit smaller than the plastic one!
Paul Turner
posted on 16/2/16 at 11:35 AM Reply With Quote
Originally posted by RenaThanks! Looks a bit smaller than the plastic one!
Its exactly the same dimensions but made of alloy.
Rena
posted on 16/2/16 at 11:36 AM Reply With Quote
OK!
Snuggs
posted on 16/2/16 at 04:29 PM Reply With Quote
I think it was Ģ140 + delivery
All content Đ 2001-16 LocostBuilders. Reproduction prohibited
Running XMB 1.8 Partagium [Đ 2002 XMB Group] on Apache under CentOS Linux
