Author: Subject: Oil temp sender ?
mcerd1
posted on 26/2/16 at 07:24 AM Reply With Quote
Oil temp sender ?
What's the best place to fit an oil temp sender on a pinto ?
I'm not planning to use an oil cooler (unless the gauge tells me I need one) so its effectively just the stock setup at the moment
Jenko
posted on 26/2/16 at 12:36 PM Reply With Quote
You can get sump plugs with drilled through thread, the sender then screws in.
MY BLOG - http://westfieldv8.blogspot.co.uk/
snapper
posted on 26/2/16 at 01:46 PM Reply With Quote
I am told the sump plug option is not the best
I have a sump plug mod and it didn't work at all
Other options are a filter baseplate adaptor which has t handy take off plugs
I eat to survive
I drink to forget
Adamirish
posted on 26/2/16 at 06:12 PM Reply With Quote
Oil pressure switch? Just a t piece from that. That's how mine is setup(Xflow). I'm running pressure, temp and a low pressure light from it.
MK Indy 1700 Xflow
ElmrPhD
posted on 26/2/16 at 10:14 PM Reply With Quote
VDO told me, directly, that the oil drain plug was a lousy place to have the sender and several have experienced that to be the case.
I'm about to have my sump tapped for a sender once I first get the new baffle plate positioned.
Others utilize a sandwich plate at the filter, which usually is part of an oil-cooler setup.
Steve, in the NLs
posted on 27/2/16 at 11:47 AM Reply With Quote
There is no real diiference between tapping the sump for a sensor or tapping the sump plug -- the readings will be within a few degrees and likeky read surprisingly cold.
The oil temperature going to bearings is the main temperature going to the bearings not easy to measure without a cooler or remote filters.
If it is only to find out if a cooler is required or not for temporary test rig I would use a K-type thermocouple held on to the oil filter housing with a band of tank tape ---- cheap simple and accurate.
DUAL TWO CHANNEL 2 K-TYPE DIGITAL THERMOMETER THERMOCOUPLE SENSOR 1300°C cheap as chips easy to use and much faster resposne the than thermistor types.
