Author: Subject: FS - Megajolt/E,EDIS4, VR sensor and wiring
thepest
posted on 12/3/16 at 07:23 AM Reply With Quote
Switched to Megasquirt V2 so won't be needing this now.
MegaJolt/E TPS version.
Harness plug ends included.
145£ o.n.o
Link to Larger photo
johnemms
posted on 12/3/16 at 08:43 AM Reply With Quote
I've recently switched from Nodiz to Megajolt.... that megajolt is a very nice little unit on a blacktop with bike carbs... bargain for someone. .
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
MikeR
posted on 12/3/16 at 03:54 PM Reply With Quote
I thought nodiz did the same as mega jolt. Why the switch?
(And bump the same post)
johnemms
posted on 12/3/16 at 08:00 PM Reply With Quote
I have a 2.0 Blacktop & Bike carbs..
My Nodiz which when compared to an old dizzy was worlds better.
It was easy to fit & worked - but then it broke & had to be replaced.
The only way to connect & map it is via a Bluetooth dongle which never worked well for me.
Mapping software crashed a lot sometimes leaving random bin writes.
My rolling road sessions took ages with constant connection drop outs & software freeze.
I was never happy with my maps due to feeling the operator had been stressing with it.
But hey - it was easy to fit & worked..
Megajolt/e ..I really like..
It was cheap to buy - bought mine from USA online.
It has a hard wired cable & 100% reliable connection.
Very easy to setup.
Works very well when mobile on the road with a passenger & laptop.
Less map boxes make map bins far more stable & easier to adjust.
Genuine Ford EDIS coil drivers & limp home mode - (kinda feels better).
I can now switch between two maps on the fly. (Cold startup/Fuel Octane, etc).
Most rolling roads know how to use it quickly & easily.
It has big support & maps plus nice easy reliable open source software.
WesBrooks
posted on 23/3/16 at 03:38 PM Reply With Quote
Is this still available?
EDIS4 - 4 cylinder? I've not read into it yet but I assume running 8 cyclinders is minor tweaks to the loom and another coil pack?
This could be useful for getting a Thor or GEMs engine running with my 14CUX injection from my RV8 3.9! The latter two would need unlocking and I'm nervous about running an engine in on a Megasquirt even if it is my final aim!
Wes.
Edit: Nervous about running in a fiddled with engine on megasquirt...!
[Edited on 23/3/16 by WesBrooks]
http://doctrucker.wordpress.com
thepest
posted on 23/3/16 at 03:43 PM Reply With Quote
It's been sold
mcerd1
posted on 23/3/16 at 06:13 PM Reply With Quote
Yes you need a megajolt and another 4cly coil pack, but then you'll need an EDIS8 (with a plug) to run it, the EDIS4 won't cut it
Loads of info on the autosportslabs sites....
[Edited on 23/3/2016 by mcerd1]
WesBrooks
posted on 24/3/16 at 11:21 AM Reply With Quote
Cheers for the information. I'll read up on them a bit more so I'm ready next time one comes up!
Originally posted by thepest
It's been sold
Balls. I'll save my pennies then and keep an eye out for the next person upgrading to full MS!
