Author: Subject: Zetec Camshaft Sensor??
Dick Axtell
posted on 14/3/16 at 03:22 PM Reply With Quote
G'day LCB-ers;
Still plodding my way through wiring for the Nodiz Pro, for my silvertop Zetec. I reckon to have sorted most, if not all, of the necessary wiring connections.
Except for the camshaft position sensor!! Where should this be connected? None of my Haynes manuals cover this item (mainly because they're like me - too old ).
Apologies if its a daft question. Your advice on this will, as usual, be greatly appreciated.
[Edited on 14/3/16 by Dick Axtell]
Chaz
posted on 14/3/16 at 03:49 PM Reply With Quote
I'm no expert on Nodiz, but i guess its similar to megajolt??? Are you using a toothed wheel or the flywheel? If so Nodiz will have all the information it needs. I didnt need the camshaft sensor with megajolt.
I hope this helps.
On wasted spark ignition the cam sensor is really just provided for the injection system.
Jenko
posted on 14/3/16 at 05:01 PM Reply With Quote
Stupid Question......Does it actually have cam shaft position sensor?....Unless you have VVT / VCT etc.
You will however need a Crankshaft position sensor...are you getting the two mixed up?.
MY BLOG - http://westfieldv8.blogspot.co.uk/
SteveRST
posted on 14/3/16 at 05:21 PM Reply With Quote
Yes the silver-top Zetec has cam position sensor.
On my Megasquirt set up I'm not using it though - just have the sensor in place to plug the hole. (Run crank position sensor only, which uses flywheel for sensor data).
big_wasa
posted on 14/3/16 at 07:14 PM Reply With Quote
You only need it for sequential fuel injection. So you won't need it for 99% of aftermarket ecu's carb or injection.
fossett
posted on 14/3/16 at 08:38 PM Reply With Quote
Nodiz does not need this signal, just leave the sensor there dormant.
As mentioned here - it needs a crankshaft signal, and if you want the benefits of a 3d advance table, then a TPS or MAP sensor.
[Edited on 14/3/16 by fossett]
posted on 14/3/16 at 09:18 PM Reply With Quote
To expand a bit fully sequential injection systems use to identify which cylinder is on the induction stroke.
It is also increasing used on some engines to identify timing chain wear. Checking the cam-crank relative timing by looking at the signals on a dual trace oscilloscope is becoming an increasingly important diagnostic technique.
Dick Axtell
posted on 15/3/16 at 09:28 AM Reply With Quote
What an interesting range of replies!! Thanks for all your advice.
Conclusion :-
Running Nodiz doesn't require a camshaft sensor connection.
Mark100
posted on 15/3/16 at 05:16 PM Reply With Quote
what if like me you are about to start wireing nodiz to your st170 with vvt and pro controller ???????????
