Author: Subject: Noisy English Axle
AntonUK
posted on 20/3/16 at 10:10 PM Reply With Quote
Noisy English Axle
So after a successfully MOT yesterday and some nice weather today I took the car for a little run out.
Biggest issued I've found so far is the rear axle is very noisy., it sounds like its straight cut. Its much louder than the exhaust.
I suspect it's a worn Crown wheel and Pinion. It didn't look 100% last time it was out, but didn't want to spend the ££ on a new set without first testing it.
Question 1: Except for being really annoying do I risk damaging anything by continuing to use it?
Question 2: Can you recommend any good re-builders?
For Info its a 35 tooth crownwheel which I believe is 3.89:1 Ratio with LSD.
Build Photos Here
ali f27
posted on 20/3/16 at 10:51 PM Reply With Quote
PROBS JUST THE BEARINGS
dmac
posted on 20/3/16 at 11:34 PM Reply With Quote
A bit obvious I know but have you checked the oil level?
DMac
19sac65
posted on 21/3/16 at 07:02 AM Reply With Quote
Arrow engineering is regarded as one of the best for english diffs
AntonUK
posted on 21/3/16 at 08:31 AM Reply With Quote
Local too
Would anyone have a phone number for them? I can't find one online
Build Photos Here
posted on 21/3/16 at 09:10 AM Reply With Quote
Is it howling/whining or a rough dry abrasive growl sound?--- if the later it is likely just the halfshaft bearings or if you are very lucky a rear brake issue also check nothing is rubbing on the propshaft. If a howl/whine check the oil level before pulling anything major apart.
19sac65
posted on 21/3/16 at 09:43 AM Reply With Quote
Local too
I think its
Arrow auto engineering
07891 604755
He used to be a contributor on this site
Dont know if hes still active
Mr Whippy
posted on 21/3/16 at 12:45 PM Reply With Quote
does it have poly bushes as these can be a mistake on road cars due to them making the diff whine vastly louder than rubber bushes
AntonUK
posted on 21/3/16 at 07:20 PM Reply With Quote
Local too
I think its
07891 604755
Thanks I've spoken with him, tonight's job is to start stripping down.
Build Photos Here
