Author: Subject: Retrofit cage
The Knobs
posted on 26/3/16 at 03:34 PM Reply With Quote
Retrofit cage
Is it possible to retrofit a full cage to a vortx easily or is it a back to factory for bits to welded on?
posted on 26/3/16 at 11:02 PM Reply With Quote
Yep, I fitted a front loop and bars to the room bar on my MNR.
The roll hoop was welded in and I made the front bit bolted in. It was a front loop with two bars back the original bar with a diagonal across the top bars.
posted on 26/3/16 at 11:05 PM Reply With Quote
here it is...
posted on 26/3/16 at 11:09 PM Reply With Quote
The Knobs
posted on 26/3/16 at 11:15 PM Reply With Quote
Same as I did with my Striker then. Just looking for a suitable MNR then now.......
