Author: Subject: More alternator issues
furryeggs
posted on 30/3/16 at 06:50 PM Reply With Quote
Can anyone gelp, My alternator came with my retro ford kit. Its a 70 amp ACR type and it seems to have at least 6 terminals.
3 pin plug (2 big 1 small) the small pin has a wire running up to a second set of terminals d+ b+ and w
My loom has the 3 pin pre wired with 1 thin wire (warning light?) and a larger cable (battery), this fits but only if i remove the link wire to the second terminals.
where do a connect up?
I can upload a pic if needed
[Edited on 30/3/16 by furryeggs]
posted on 31/3/16 at 06:28 PM Reply With Quote
3 pin connector, two 6.8 mm spade - connected together - are charge wires; this is higher output alternator so two wires to carry the current. third 4.7 mm is to charge lamps
the others are probably as below.
furryeggs
posted on 1/4/16 at 05:28 PM Reply With Quote
So i should be able to just run the 3 pin connection, 2x battery leads to +v and 1 to warning light + battery negative to B-. I won't be using split charge so i assume the others can be left?
furryeggs
posted on 13/4/16 at 05:36 PM Reply With Quote
[img][/img]
spent 5 minutes with my meter checking the connections. there's a few that are all B+, so were do I connect to?
Dusty
posted on 13/4/16 at 09:02 PM Reply With Quote
You can connect with a standard lucar three pin connector which has two large spades, both B+ and a small spade for the warning light. Take the grey/yellow spade off W.
Or if more convenient bolt main battery pos lead to the B+ terminal at the 7 o'clock position and warning light wire to W at the 5 o'clock position. Either will work fine and it's a matter of convenience, what connectors you already have on your loom, etc.
Oddified
posted on 15/4/16 at 01:28 PM Reply With Quote
Originally posted by furryeggs
[img][/img]
From experience using those Lucas A127 alternators, use the stud/nuts to connect to, way more reliable than the 3 lucar connectors if your using a few amps and high rev's.
Ian
