Author: Subject: Oil temp sender connector
Gemini
posted on 5/4/16 at 01:11 PM Reply With Quote
Hi all
does anyone know where you can get a connector which pushes onto the oil seneder or temp senders.
I cant find anyone that sells them.
Does anyone have any on an old loom possibly?
Its on a ford 1600 crossflow.
I think the pinto senders are the same style and probaly others from that era. 70's 80's
[Edited on 5/4/16 by Gemini]
HowardB
posted on 5/4/16 at 02:31 PM Reply With Quote
which engine?
Howard
Gemini
posted on 5/4/16 at 02:51 PM Reply With Quote
posted on 5/4/16 at 03:54 PM Reply With Quote
Oil temp? Don't you need a sensor in the sump below the oil line??
Gemini
posted on 6/4/16 at 08:30 AM Reply With Quote
hi
i am looking dor the small plug that pushes on to the end of one of these for the electrical wire.
Intermotor Oil Pressure Switch - 50590 - For FORD Push Rod KENT engine
adithorp
posted on 6/4/16 at 09:16 AM Reply With Quote
Search for "bullet terminal" should find what you want
http://jpsc.org.uk/forum/
