Author: Subject: Measuring 12 point spline / tri square sockets
r1_pete
posted on 25/4/16 at 10:40 AM Reply With Quote
My Porsche flywheel is bolted on using 12 point socket head bolts.
Can someone help me with how to measure them, from point to point it measures 11.5mm, so would that be an M12 socket?
I just want to buy a single socket, as I'll probably never use it again, so don't want to buy a set.
I thought I had a pinto head bolt socket, which from memory looked a similar size, but I can't find that.....
Cheers.
Pete.
Slimy38
posted on 25/4/16 at 11:01 AM Reply With Quote
http://www.metalnerd.com/downloads/triplesquaretable.pdf
11.6mm is M12.
posted on 25/4/16 at 11:04 AM Reply With Quote
I'm not sure how you size them to a socket, but asking a good nut & bolt supplier they may know the answer or better still the size you need. I can't imagine a Porsche dealer being too helpful although a Porsche mechanic may be if you can speak to one.
posted on 25/4/16 at 04:03 PM Reply With Quote
Whats the point of buying one socket a set of the common sizes cost buttons on eBay.
loggyboy
posted on 25/4/16 at 04:25 PM Reply With Quote
12 point spline is just a normal hex socket with double spaced hex. most standard sockets are double hex.
ETA -
apologies they are female bolt!
in which case i got these - cheap as chips and more than up to job for even heavy duty jobs.
420365A 40Pc Torx Star Spline Hex Socket Bit Set 3/8 And 1/2 Drive Repair Tools
[Edited on 25-4-16 by loggyboy]
Mistral Motorsport
