Author: Subject: a few questions
Mark100
posted on 27/4/16 at 01:54 PM Reply With Quote
a few questions
Couple of questions as its about time to start putting stuff in its final place
1. breather catch tank for the oil what hieght in relation to the rocker cover ? does it need to be highter
2. header tank for water anywere on rear shelf ok or need to be specific
3. is it a good idea to put ecu,s under the dash or protected from the elimants in the engine bay ive seen all whitch is bests
4. the tape that goes round the nosecone were it touches the bonnet any type to use in particular ??? neoprene ??
thanks
steve m
posted on 27/4/16 at 02:03 PM Reply With Quote
"Couple of questions as its about time to start putting stuff in its final place "
"Mine is around the top of the rocker cover, and the feed pipe is horizontal with the can, and cover"
"not applicable in my case"
"again not applicable on a xflow, but i would mount it inside if i did have one"
thanks
"20mm x 10mm rubber sticky back trim, bought from a kit car show, so unablet find its name, sorry!"
big-vee-twin
posted on 27/4/16 at 02:33 PM Reply With Quote
Mount catch tank on shelf at raer of engine next to it mount your expansion tank for water.
ECU under dash as they do not like heat mine is in top of passenger footwell and easy accessible.
You can get 20 x3 mm foam tape off ebay.
http://www.triangleltd.com
posted on 27/4/16 at 03:42 PM Reply With Quote
On my Pinto engine MK Indy I mounted the oil catch tank on the front of the scuttle under the bonnet. It was probably level with the cam cover, but it was above the block vent. In 3 years I never had a drop of oil in it so question if I needed it.
Mark100
posted on 27/4/16 at 04:46 PM Reply With Quote
thanks Lads will crack on when it stopps snowing
could i trouble you for a couple more
st170 water pump pumps Right way or change it ????
st170 no need for petrol return normaly but as ive put on bike carbs should i add a return ??
the seats i have are fibre glass smooth front but the backs a bit ruff and unsightly how have you finished this neatly (just sprayed or is there a speacail paint )
is there a specific alternator belt to use or just any that fit
i have webber fuel filter and pump on a shelf next to the tank then to fse pressure regulator would i need to fit a second filter after the fse
thanks again
