Author: Subject: Zetec Blacktop noise identification
Plunky
posted on 1/5/16 at 01:49 PM Reply With Quote
Afternoon all,
I have recently replaced the silver top Zetec in my F27 with a blacktop.
When I initially got the new engine up and running it seemed all ok bar a tweak or two with the map, however it has now developed a ticking/tapping noise.
I have uploaded a video below.
Can anyone point me in the right direction of the problem and hopefully how to fix it please...
http://youtu.be/JwLGqZtpDfc
Liam
Plunky
posted on 6/5/16 at 05:52 PM Reply With Quote
Can anyone help?
ianm67
posted on 6/5/16 at 06:16 PM Reply With Quote
Knackered cam follower? How many miles has the engine done?
Always biting off more than I can chew.....
Plunky
posted on 6/5/16 at 08:02 PM Reply With Quote
I was told around 40k, but have no proof.
How would I identify this is the issue?
chris
posted on 6/5/16 at 08:29 PM Reply With Quote
it may have slipped a shim out of follower
SJ
posted on 7/5/16 at 12:36 PM Reply With Quote
My blaktop mad a similar, but not exactly the same noise and that was a badly worn piston and bore causing piston slap. I don't think yours is the same but if you can't find anything wrong on the cam front I'd take the head off and have a look.
Link
Stu
Plunky
posted on 7/5/16 at 04:07 PM Reply With Quote
How would I check this?
chris
posted on 7/5/16 at 11:09 PM Reply With Quote
Take cam cover off and the shims sit in-between the cam and follower they look like a 10 pence piece
Plunky
posted on 21/5/16 at 12:15 PM Reply With Quote
The noise is only there when the engine gets hot
Plunky
posted on 23/7/16 at 04:29 PM Reply With Quote
Struggling with this one....
Anyone got any other ideas?
posted on 23/7/16 at 04:43 PM Reply With Quote
What's your oil pressure like when its hot?
And, have you got the correct ford oil innit??
Plunky
posted on 23/7/16 at 04:47 PM Reply With Quote
No I idea on the pressure front as I don't have a gauge.
Is it easier enough to fit one? What should the pressure read when hot?
Correct oil, 5w30 if I remember correctly.
posted on 23/7/16 at 04:52 PM Reply With Quote
Mine was about 40 cold and up to 80psi hot. That was head pressure as I had mine plumbed into the handy 1/8th npt up there..
Anyone else got any hot oil pressure info to share???
posted on 23/7/16 at 04:57 PM Reply With Quote
Shims are under the buckets as well...
big_wasa
posted on 23/7/16 at 06:06 PM Reply With Quote
Shims are on top of the bucket.
big_wasa
posted on 23/7/16 at 06:28 PM Reply With Quote
What have you done with the sump as that sounds like a rod slapping the windage tray ?
Have you fitted arp rod bolts or disturbed them ?
Plunky
posted on 23/7/16 at 07:01 PM Reply With Quote
I've fitted a Raceline sump. The noise Only happens when the engine is hot though, Wouldn't it happen when cold too if it was something hitting the sump?
Haven't touched the rod bolts.
Plunky
posted on 1/8/16 at 07:12 PM Reply With Quote
Bump
obfripper
posted on 1/8/16 at 08:27 PM Reply With Quote
Check your cambelt timing, it does sound like mechanical contact possibly from the top end.
I had an alfa that had been overrevved and had sheared a cam pulley key, and the pistons were clipping the valves due to the extra advance on the camshaft causing it to tick like the tappets were wrongly adjusted when hot - luckily when retimed all was fine, another few degrees would have needed a top end rebuild.
If the timing is correct, run up til the noise is clearly audible, stop and remove all the spark plugs and turn the engine by hand slowly feeling for any unusual changes in resistance and any noise.
If the rattle is from the small end, it should reduce if you disconnect the injector for the affected cylinder - engine off, disconnect then start up engine for each cylinder in turn and listen for changes in the rattle.
Dave
Plunky
posted on 3/8/16 at 08:21 PM Reply With Quote
Thanks Dave.
Would be a relief if it was something as simple as the timing being out!
