Author: Subject: Zetec Alternator Bracket
AntonUK
posted on 19/5/16 at 09:33 PM Reply With Quote
My Silvertop alternator bracket has snapped again. I believe it to be a Ginetta made thing that weigh's more than the moon. Ive welded it twice and others have tried beforehand. appears to snap in 4 different places.
Anyone tried one of these?
TIGER KIT CAR ZETEC ENGINE ALTERNATOR BRACKET - FITS SILVERTOP & BLACKTOP - NEW!
Build Photos Here
johnemms
posted on 20/5/16 at 09:36 AM Reply With Quote
Silly question but.. do you have a spacer crush tube between the lugs?
[Edited on 20/5/16 by johnemms]
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
AntonUK
posted on 20/5/16 at 11:55 AM Reply With Quote
No I don't will that make much difference?
Build Photos Here
johnemms
posted on 20/5/16 at 08:51 PM Reply With Quote
AntonUK
posted on 21/5/16 at 07:04 AM Reply With Quote
Interesting, although both my lug's had independent bolts not one long single.
Lug's still failed.
Will knock up a tube later
Build Photos Here
johnemms
posted on 21/5/16 at 07:33 AM Reply With Quote
I think the best answer is to fit a tensioner..
When you rev an engine you can see the tensioner moving on a cam belt keeping correct tension..
Got to be similar on your alternator pulley preventing constant tugging on alternator brackets..
Has anyone figured out and fitted a generic aftermarket tensioner to fit on a 2.0 Blacktop?
I have a solid idler pulley adjuster - i will make a locost tensioner at some point..
