Author: Subject: 1UZFE Manual Gerabox options
duke
posted on 23/5/16 at 07:09 AM Reply With Quote
Hi All,
Looking for manual gearbox options for a Lexus 1UZFE engine.
Something cost effective would be good?
Any help would be great.
Jay.
SPYDER
posted on 23/5/16 at 08:12 AM Reply With Quote
Hi Jay. Google is your friend. There are tons of threads on tons of websites covering this conversion.
"Cost effective" is going to be the stumbling block.
Cheapest could be a modded IS200 six speed. I have used this on my 3SGE engined car. I paid £20 for one box and £1.20 for a spare.
There are conversions using diesel BMW boxes, 350Z boxes, various Toyota boxes, you name it.
Most use an adapter plate but some do a "cut and shut" operation with the 1UZFE bellhousing and gearbox of choice.
Just Google it.
Badger_McLetcher
posted on 23/5/16 at 07:28 PM Reply With Quote
Aye, AFAIK there are no manual gearboxes which marry straight to the engine, all require an adapter plate.
Also I don't think there is a flywheel which bolts straight to the 1uz-fe crankshaft, so a new or modified one is required. Clutch must match gearbox and flywheel, obviously.
They are bloody good engines but doing a manual conversion is unlikely to be cheap, unfortunately.
If disfunction is a function, then I must be some kind of genius.
duke
posted on 24/5/16 at 05:16 AM Reply With Quote
Thanks guys.
Done a bit of research and the BMW route looks good as a company near me seem to have it sussed.
Not overly cheap ( £1000 ish ) but for such a good cheap awesome engine still seem like good value.
Jay.
froggy
posted on 24/5/16 at 07:35 AM Reply With Quote
I did mine using a supra r154 box £500 and an adaptor made from a drawing I bought off the net £10 + £300 machining and ally cost . 3sgte flywheel with holes slotted 3mm to suit the v8 £50 and some arp bolts £15. Camry v6 clutch £80 and adapted the mr2 clutch fork so it has an external slave Cyl using a classic mini cylinder £25
[IMG]http://i144.photobucket.com/albums/r187/froggy_0[IMG]
duke
posted on 25/5/16 at 07:07 AM Reply With Quote
Did a bit more research and going down the BMW route.
Very good boxes for no money.
Drift Moto in West Kingsdown have all the bits for a no hassle solution.
Cheers.
froggy
posted on 25/5/16 at 08:20 AM Reply With Quote
v6 Camry clutch I've fitted has coped pretty well with mine so far especially as it's twin turbo with 370 lb ft
Ugg10
posted on 25/5/16 at 08:56 AM Reply With Quote
Originally posted by duke
Thanks guys.
Jay.
1JZ 2JZ Manual Gearbox Conversion Bmw Gearbox Adaptor Plate Swap
also from the US for Nissan 200sx s13 box - flywheel, clutch and adaptor for $750 (approx. £500 plus shipping + taxes)
http://collinsadapters.com/index.php/adapter-plates/toyota.html
[Edited on 25/5/16 by Ugg10]
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
duke
posted on 25/5/16 at 08:06 PM Reply With Quote
Thanks again.
Going down the BMW route from Drift Moto as they are near to me and the stuff looks good.
Seems like a no brainer way of gettting quad cam 280 + BHP and a manual box.
Jay.
