Author: Subject: Which ford gearbox mount is this please?
FuryRebuild
posted on 23/5/16 at 08:35 AM Reply With Quote
Dear Collective Mind
Due to personal numptiness, I managed to tear the rubber in this gearbox mount. It's from a 4 speed ford (rocket?) box, mounted in my Fury.
I want to order a shiny new one from Burton's today, but don't want to until I'm sure I have the right one. Any ideas which I should be asking for?
Thanks All
www.furyrebuild.co.uk
mcerd1
posted on 23/5/16 at 08:48 AM Reply With Quote
that's a std. Sierra / Granada mount
like this:
sierra / granada type mounts
(Left: ford OE, Right: generic aftermarket)
although most people prefer the older and much firmer 4 speed mount (Cortina etc - as used by westfield and caterham)
but they are smaller and would need mods to the chassis mounts:
4spd type mount :)
4spd type mount :)
[Edited on 23/5/2016 by mcerd1]
posted on 23/5/16 at 08:49 AM Reply With Quote
From memory that looks the same as the rear gearbox mount on a type 9 box. IIRC you can get a stiff one from Westfield that helps limit movement of the rear end of the box (I used one on my MK Indy build).
r1_pete
posted on 23/5/16 at 08:54 AM Reply With Quote
Demon Tweaks do a Vibra Technics mount, which uses two round rubber isolators if you want stiffness.
posted on 23/5/16 at 09:52 AM Reply With Quote
Burton Power do one here...
http://www.burtonpower.com/std-gearbox-mount-ford-sierra-5-s peed-type-9-gbt9400.html
Westfield do one here...
http://parts-shop.westfield-spo rtscars.co.uk/index.php?route=product/search&search=type%209%20gearbox%20mount
[Edited on 23/5/16 by nick205]
Ugg10
posted on 23/5/16 at 10:29 AM Reply With Quote
There's a guy on ebay that supplies these in two different stiffnesses
Morgan Ford Lotus Kit car gearbox mount rwd 4 &5 speed inc type 9
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
FuryRebuild
posted on 24/5/16 at 01:15 PM Reply With Quote
Many thanks for all the ideas. I'll go for a vibra-technics one if Burtons have it.
thanks
mark
MattD
posted on 24/5/16 at 01:53 PM Reply With Quote
Rally Design are cheaper
http://www.rallydesign.co.uk/product_info.php?cPath=1740_1743_1771&products_id=13085
mcerd1
posted on 24/5/16 at 02:31 PM Reply With Quote
^^^ aren't those ones made to the Cortina/ Westfield/ Caterham dimensions?
Meaning that they are significantly narrower mounting centres and a different height compared to the sierra one your replacing....
