Author: Subject: 5VY plumbing??? PLEASE
Wes
posted on 24/5/16 at 07:57 PM Reply With Quote
Hi all,
I'm in the process of trying to plumb my engine R1 5VY engine into my MK indy and having a nightmare. I don't suppose anyone has a drawing or could sketch me a quick one at all? I'd be very grateful as I've been on it for 4 weeks now and got nowhere.
Many thanks
Wes 07515934136 or wesleykos@hotmail.co.uk
adithorp
posted on 24/5/16 at 08:34 PM Reply With Quote
No diagram but from memory...
Thermostat housing to top of rad. Bottom of rad to water pump inlet pipe (steel pipe with drain screw in it). Small pipe near sprocket to throttle body thermo-valve and other side of that goes to small pipe on head beneath TB's. Outlet from oil cooler T'd into top hose. Expansion bottle (used VW globe type) lower outlet T'd into bottom hose. Rad' bleed and 'stat bleed T'd together and into top of expansion bottle.
http://jpsc.org.uk/forum/
Wes
posted on 24/5/16 at 08:40 PM Reply With Quote
OK thanks for that. I'll have a good look tomorrow and see if I can put all that together. Thank you very much for your reply.
Coopz
posted on 24/5/16 at 09:25 PM Reply With Quote
This thread should be of use:
http://www.locostbuilders.co.uk/viewthread.php?tid=135068
Coopz
posted on 24/5/16 at 09:28 PM Reply With Quote
If you're still struggling, message me and I will take some pictures of my install.
Good luck!
