Author: Subject: 3 cylinder zetec.
Myke 2463
posted on 6/6/16 at 10:41 AM Reply With Quote
3 cylinder zetec.
My 2.0 silvertop is only sucking on 1 2 3 not no4.
running GSXR 600 tb all opening together.
Compression on all 4 is 140 bar with tb's open, leads, plugs and coil all working ok,
Could there be a problem with hydraulic tappets, ?
Any ideas welcome Cheers guys somebody always has the answers on here.
Be Lucky Mike.
Daf
posted on 6/6/16 at 11:16 AM Reply With Quote
What exactly do you mean by sucking? If you're getting the same compression across all 4 then the same amount of air must be going in. Problems with tappets and valves would show up on a compression test.
Have you tried balancing the throttle bodies with a proper balancer - this makes a massive difference to the running of the car in my experience.
Ugg10
posted on 6/6/16 at 12:10 PM Reply With Quote
manifold, injector or connecting rubber air leak, have you pulled the plugs to see what colour they are or looked at exhaust header temperatures ?
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
posted on 6/6/16 at 12:48 PM Reply With Quote
140 bar would be impressive, hopefully you mean PSI
As said, you need to clarify what you mean by "not sucking".
chris
posted on 6/6/16 at 06:07 PM Reply With Quote
I had the same problem when I was running bike carbs on a pinto I tried everything to cure it in the end changed the head gasket and that cured it
