Author: Subject: I do not know the name, look, please, :-)
Samuele
posted on 9/6/16 at 07:15 AM Reply With Quote
Can you tell me where I can find these pieces blacks on the body?
and mounted on the rear fenders.
tanks
[img][/img]
jeffw
posted on 9/6/16 at 07:25 AM Reply With Quote
From Fury Sportscars....they are wheel arch extensions
Samuele
posted on 9/6/16 at 07:35 AM Reply With Quote
Many many thanks Jeff.
WallerZero
posted on 9/6/16 at 08:22 AM Reply With Quote
BBQ lid DIY job that!
BBQ Arch Extensions
http://zachsgbszero.blogspot.co.uk/
jeffw
posted on 9/6/16 at 08:34 AM Reply With Quote
I suspect the fibreglass ones maybe cheaper than chopping up a barbeque.
WallerZero
posted on 9/6/16 at 08:58 AM Reply With Quote
Depends if you have an old bbq lying around lol
The fiberglass ones will probably look better anyway. Might be worth having a look and seeing if MX5 ones may do the job if you can't get them direct
MikeR
posted on 9/6/16 at 10:17 AM Reply With Quote
Old style mini's used to fit them - may be another source if needed but be careful with the size.
mark chandler
posted on 9/6/16 at 12:16 PM Reply With Quote
I cut mine the arches on my tub up, glassed the gap, filled and painted
avatar
avatar
Samuele
posted on 9/6/16 at 01:00 PM Reply With Quote
York your way to the body and gorgeous.
I 'd also like to have them myself, in front and behind , like yours.
unfortunately I have no idea how to do and how you work this material .
So I do it is to just buy them .
I wrote to furysportscar .
I hope I do know as soon
mark.s
posted on 9/6/16 at 01:16 PM Reply With Quote
MINI WHEEL 2.5" ARCH SET PLASTIC ARCHES FITS CLASSIC MINI MK3 ONLY Z2122
Must be cheaper than cutting up 4 lids , don't take these as "the ones " there is loads on eBay have a look
Samuele
posted on 24/8/16 at 06:42 AM Reply With Quote
someone has an idea where I can find similar items?
the Furysportscar seems to not want to / can get these pieces.
since I have an original piece I did not even no measure, I do not even know what to look for on the internet.
maybe someone has not bought the original pieces that went well too.......
agors
posted on 30/8/16 at 07:58 PM Reply With Quote
On Internet there are people that can make it for you, try to search.
I'm asking to make some fender in carbon for my Westfield, if they say yes, I'll give you the contact.
jeffw
posted on 30/8/16 at 09:26 PM Reply With Quote
There are loads on ebay
eg
Universal flares fender flare wheel arch extension arches trims jdm wide set h
Samuele
posted on 31/8/16 at 07:07 AM Reply With Quote
thanks Jeff.
try these pieces.
the measures which you believe are very similar to those for the fury?
or you have to change a lot?
Samuele
posted on 31/8/16 at 07:16 AM Reply With Quote
By itself I know someone who works on carbon.
I also did make already die pieces.Unfortunately I can't use them for anything I....
but in the case of fury I wanted to have original parts.
or at least buy the pieces and assemble them simply.
can I make them produce from this friend of mine, but I have to do before the shape, then a few pieces.
then some changes ...
that's why I wanted to buy them already fit and finished to use my time on other Things
[img][/img]
