Author: Subject: Vibratory Tumbler
SmudgerEBT
posted on 13/6/16 at 07:12 PM Reply With Quote
Vibratory Tumbler
So, looking at various ways of rust removal of bolts, nuts, bits and bobs of alloy parts (like carb inlet)
Have noticed this on ebay:
Invicta Superfinish Vibratory bowl deburring tumbler machine polishing finishing
So if Forge use it......................
Anyone else used one, know of a cheap place for them (if they worked for you). I know frost autorestoration used to do one but now no longer.
Yes it might be expensive in the short term, but having a few mates who will throw stuff in as well am hoping long term cheaper than buying new bolts all the time.
bi22le
posted on 13/6/16 at 07:28 PM Reply With Quote
We had one of these at my old work. We used to use it for deburring.
It worked well. It was noisey and you have to change the stones every now and then.
Ours was a tombola style roller. Not sure about these vertical ones as our one really threw bits around inside.
Please read my ring story:
Rosco86
posted on 13/6/16 at 08:38 PM Reply With Quote
We have one of these at work, very noisy and messy as it runs wet, I don't think it would clean bolts very well, they can be quite harsh to, ie damage threads etc, also small parts would be hard to find amongst the stones, I think a wet bead blaster would be better
My Build Thread
SmudgerEBT
posted on 13/6/16 at 08:53 PM Reply With Quote
https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjEhOHN7aXNAhXEJMAKHfD8CC4Q Fgg0MAA&url=http%3A%2F%2Fwww.frost.co.uk%2Fmotor-parts-vibratory-tumbler-rust-remover-polisher-polishing-8-kg-car-parts.html&usg=AFQjCNGa0nK8O NFkCG3dzs8VekK-GZnoFQ
This looks about right for doing carbs, engine steadies, brackets, bolts etc
Two stage, one for getting rid of the rust etc, next for final polish (for brackets)
Of course a massive one would be nice for doing bottom arms etc but impossible to justify the cost for a non-business
AdrianH
posted on 13/6/16 at 09:02 PM Reply With Quote
Build one
http://www.mig-welding.co.uk/forum/threads/another-finishing-tub-build.56301/
But I doubt it would be very good for nuts and bolts, buy new ones?
Adrian
Why do I have to make the tools to finish the job? More time then money.
Wadders
posted on 13/6/16 at 09:03 PM Reply With Quote
I thinks some of them use walnut shells or similar as the abrasive medium, which would probably be a bit kinder to the bolts.
SmudgerEBT
posted on 13/6/16 at 09:19 PM Reply With Quote
With the car being such a bitza finding new bolts could take some time.
Idea is to have the larger parts powder coated and the smaller brackets, bolts, carb inlet cleaned and then rattle can clear coat.
Just looking around for ideas, reviews of kit etc
(Thinking that the 18lb on should be able to take things like oil filter housing, temp housing, carb inlet, which can go in, get cleaned then 2nd go with a polishing media (since they are alloy) which should produce a nice finish once got the right media and water ratio that is)
Mark100
posted on 13/6/16 at 09:30 PM Reply With Quote
used walnut shells and sharp dry sand as abrasives in a old electric cement mixer £50 ebay just ran it for a couple of hours with a plastic bag bungie corded to block the front off worked a treat
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
Building: Run 2 ltr Black Top in single seater race car.
posted on 14/6/16 at 08:33 AM Reply With Quote
Some people that I know made one out of a large Calor cylinder. It was used every day in a commercial environment cleaning mill scale off loads of brackets. Worked a treat.....
posted on 14/6/16 at 09:11 AM Reply With Quote
We used to use a concrete mixer filled with grit at work. It worked well and gave us the option of mixing concrete as well.
