Author: Subject: Suspension bolts
Snuggs
posted on 16/6/16 at 06:17 PM Reply With Quote
Suspension bolts
8.8 steel or A2 stainless ?
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
posted on 16/6/16 at 06:22 PM Reply With Quote
8.8 , I wouldn't use stainless
Snuggs
posted on 16/6/16 at 06:25 PM Reply With Quote
Cheers Mel
Dave Bailey
posted on 16/6/16 at 07:32 PM Reply With Quote
As said definitely not stainless. I have used 8.8 and 12.9 on steering UJ's etc...
Dave B
907
posted on 17/6/16 at 05:58 AM Reply With Quote
A2-70 SS are low tensile, standard bolts.
I have used A4-80 which are a higher strength stainless bolt.
Paul G
FuryRebuild
posted on 17/6/16 at 06:56 AM Reply With Quote
Stainless goes brittle in reciprocating loads - you need high tensile. It's great if the load isn't under any vibrational loading.
www.furyrebuild.co.uk
posted on 17/6/16 at 07:45 AM Reply With Quote
I used 8.8 set screws at either end of the shocks on my MK Indy - didn't suffer any mishaps with this setup. From experience of a pro welder friend fabricating a stainless trailer I'd be apprehensive of using stainless bolts as I'd imaging they'd get damaged after a while.
posted on 17/6/16 at 02:42 PM Reply With Quote
AN bolts are the best to use imo
cliftyhanger
posted on 17/6/16 at 07:12 PM Reply With Quote
I would not be using set screws in suspension components. You want a shoulder where there are any stresses (badly worded)
907
posted on 18/6/16 at 04:11 AM Reply With Quote
I must admit that until I Googled AN I didn't know what it stood for.
I'm impressed. Did they cost an arm and a leg ?
Paul G
Myke 2463
posted on 18/6/16 at 07:08 AM Reply With Quote
Stainless bolt grades
A2-70 = 7.0 304 material.
A4- 80 = 8.0 316 material.
Be Lucky Mike.
mcerd1
posted on 18/6/16 at 07:57 AM Reply With Quote
^^^ sort of....
A2 is of equivalent corrosion resistance to 304, and A4 is equivalent to 316
(the actually come in A1 to A5)
The second part of the grade is the strength, but that has more do do with how its been worked, they come in 50, 70 or 80 and you can get 100 as a special...
Of course that's only the austenitic ones.....
As above their properties are not ideal for suspension bolts - 8.8 (or maybe 10.9/12.9 is some cases) are your best bet
posted on 18/6/16 at 01:25 PM Reply With Quote
Paul G
Not really, just a bit of pain to find them! All over USA but not much here.
Maybe once we vote out of the EU someone can import them from the US
907
posted on 18/6/16 at 02:41 PM Reply With Quote
Paul G
Well me and the missis will be be doing our bit.
Vote OOOT
johnH20
posted on 18/6/16 at 03:57 PM Reply With Quote
Trident Racing Supplies based at Silverstone have a massive range of AN hardware. They do mail order. Not that expensive either for life and limb items. Their catalogue is a must have ( also on line ).
mcerd1
posted on 18/6/16 at 10:35 PM Reply With Quote
https://www.lasaero.com/site/products/category?id=S025T36QZ
[Edited on 18/6/2016 by mcerd1]
phelpsa
posted on 19/6/16 at 05:45 PM Reply With Quote
Not really much point using them when the size is so over spec and the tolerances on the mating parts so poor.
posted on 19/6/16 at 06:04 PM Reply With Quote
My car has AN bolts for all the suspension stuff - the main reason I used them is so that I could get the correct lengths of plain shaft and threaded bit. The range of sizes is so broad that I was able to get the thread in just the right place, at the point where it comes out of the bracket. They're also made of high-grade steel.
Unfortunately (for me) although I bought them from what I thought was a UK supplier, they were just an agency for a USA company, so I got severely stung for import duty and courier handling charges - nearly doubled the price.
Neville Jones
posted on 22/6/16 at 09:58 AM Reply With Quote
LAS Aero, Trident, Autosport Bearing Supplies, and a number of others have AN bolts in stock.
I've been using 8mm ground shoulder bots from Cromwell(and others) for the purpose for near 30 years.
