Author: Subject: Sylve RIOT track car opinions?
Nickp
posted on 20/6/16 at 06:42 AM Reply With Quote
A mate's thinking of buying this as a track car - SYLVA RIOT ZZR1400 TRACK CAR / HILL-CLIMB /SPRINT
I seem to think it's been discussed on here before but can't remember the general consensus.
Why would it need a Power Commander to pass emissions on a std ZZR lump / ECU??
Ugg10
posted on 20/6/16 at 08:01 AM Reply With Quote
I think I remember reading somewhere that bike engine are very fussy about the airbox design as these are designed to work using a ram air intake arrangement, obviously if you remove this then the fueling may well be up the shoot so the power commander helps bring this back in line. Change of exhaust may also be a factor.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
hkp57
posted on 20/6/16 at 11:38 AM Reply With Quote
It would need to be a very windy MOT station for the Ram air to work sitting still.
Fleet
SKC Raptor R - Hayabusa
Toyota C-HR Hybrid Limited Edition
Honda VFR1200 CrossTourer
DCT
Marlin Roadster 1800
Mercedes Vito 116 Sport
skippad
posted on 20/6/16 at 11:55 AM Reply With Quote
there should be an air sensor in the loom which fits into air box or foam backplate (which i cant see in photos) this is needed to achieve correct mix.
its advised to run a power commander to get the best power curve out of this engine, i use a Pipercross foam filter and Power commander with very good results!
Thats a good priced considering nearly half of that would be cost to purchase engine!
twybrow
posted on 20/6/16 at 05:11 PM Reply With Quote
It is nothing to do with ram air. When you modify any inlet or exhaust of an oem setup you are changing the way it breathes. A Power Commander enables the map to be modified to bring it back in line with what is needed to pass an emissions test. Remember that emissions are tested stationary and at low or tickover revs, so no ram air influence.
Nickp
posted on 20/6/16 at 05:16 PM Reply With Quote
Ta for the emission info but I was more interested in opinions on the car itself TBH
daniel mason
posted on 20/6/16 at 08:14 PM Reply With Quote
Very light Nick.there was one at Blyton the other week and it went well with an r1 motor. It'll be lively but great fun and rapid
Phil_1471
posted on 25/6/16 at 06:13 PM Reply With Quote
Wonder what it will sell for... Then I know where to pitch mine, if I ever sell it haha
You can live in a car but can't rally a house
Toed64
posted on 3/7/16 at 08:33 AM Reply With Quote
Did your friend buy it?
I talked to the seller on the phone, but I did not look at it because the car has no paperwork at all, so IVA might be out of reach.
The plate mounting the reverse motor is twisted and attempts have been made to strengthen it, without success.
The radiator is rear mounted and the seller admitted that it overheats rapidly. I would front mount the rad.
Once sorted, it will be blisteringly quick.
Nickp
posted on 3/7/16 at 06:34 PM Reply With Quote
No he didn't buy it, I pretty much talked him out of it. It will make a good car, and I could've sorted it, but it just wasn't right for him as he has zero mechanical skills.
