Author: Subject: Alternator for Ford crossflow
jonbeedle
posted on 1/7/16 at 02:47 PM Reply With Quote
Hi. Does anyone have an alternator for a 1977 Ford Crossflow 1300/1600?
"Everyone is entitled to an opinion however stupid!"
posted on 1/7/16 at 03:03 PM Reply With Quote
If you are stuck I have one but the postage would be more than the value of the item.
Easier to repair your old one
It is just an ordinary Lucas ACR 17 very easy and cheap as chips to overhaul or you could fit a Lucaus A127 as used on the Escort 3 and some Sierrs and Metro.
jonbeedle
posted on 1/7/16 at 03:10 PM Reply With Quote
Thanks for the info. Not sure how to repair it but I'm sure I can find out.
posted on 1/7/16 at 04:15 PM Reply With Quote
Unless the diode pack is blown or slip rings are worn through new brushes and/or a new regulator pack will fix it no soldering involved. With alternator off the car just take the back cover off and
http://www.howacarworks.com/electrical-systems/renewing-alternator-brushes
posted on 1/7/16 at 07:37 PM Reply With Quote
Hi Jon , haven't seen you for a while, hope all is well? Any decent motor factors should be able to help with the alternator , not particularly expensive
jonbeedle
posted on 3/7/16 at 10:02 AM Reply With Quote
Hi Rusty
Hope you are well. Yes it's been a few years. Maybe we can get together once I'm back on the road
posted on 3/7/16 at 12:59 PM Reply With Quote
Look forward to seeing you.
