Author: Subject: 3m x 3m shed
Volvorsport
posted on 10/7/16 at 10:52 AM Reply With Quote
3m x 3m shed
As the title says , wanting to build a 3m square shed on the back of my new garage . I can buy a steel one for approx 500 quid . Struggling to get under that for timber unless I use reclaimed pallets / scaffold boards. It's only 3 sided . Any suggestions or pointers greatly appreciated
Ta
www.dbsmotorsport.co.uk
getting dirty under a bus
hizzi
posted on 10/7/16 at 11:32 AM Reply With Quote
have you priced using timber kit sheething ply. 2.4x1.2 sheet around£10
ian locostzx9rc2
posted on 10/7/16 at 11:34 AM Reply With Quote
Buy the wood and build it your self wouldn't cost £500 quid 3by3 inch frame external ply roof external ply sides or cladding I did it many years ago to the back of my pre fab garage .
posted on 10/7/16 at 08:29 PM Reply With Quote
I'd be surprised if external ply was good enough. Would need treating.
ian locostzx9rc2
posted on 10/7/16 at 08:39 PM Reply With Quote
I made mine with a 3 by 3 frame ply roof with roofing felt and shed cladding planks
loggyboy
posted on 10/7/16 at 08:43 PM Reply With Quote
Im half way thru doing a fairly sturdy 4x2 timber shed from scratch. Spent about 450 to date on frame, panels, paint and screws/ironmongery, and budgeting for a further 2-300 on conc base, osb/felt roof and glazing.
Mistral Motorsport
posted on 11/7/16 at 08:02 AM Reply With Quote
I'd have thought 4x2 timber frame roofed with exterior ply and felt with sides clad in overlapping horizontal exterior feather edge planks. Material cost must be sub £500 and build it yourself - finish it with an exterior grade fence type sealant and perhaps guttering to control rainwater flow. For my money a hardcore and concrete base would have to go down raising the shed off the soil to prevent rain soaking in and give you a solid floor.
ste
posted on 11/7/16 at 12:45 PM Reply With Quote
I had the same space so built this;
started by using some treated rails screwed to the fence posts
Then screwed onto that some 15mm OSB3 sheets which are external structural grade
3 x 2 studding to make the roof
Visqueen down and 3" of concrete poured.
Roof sheets are reclaimed ones from a farmer friend
Studding used to make a frame at the front
OSB screwed to the inner front wall
Then front covered with shiplap and painted with cuprinol wood paint. Door made the same way.
Here's the finished article
Not too sure on cost but probably under £500
ste
posted on 11/7/16 at 01:00 PM Reply With Quote
Volvorsport
posted on 11/7/16 at 09:07 PM Reply With Quote
Nice one.
MikeR
Contributor
Posts 8600
Registered 25/5/02
Location Hinckley
Member Is Offline
Photo Archive Go!
Building: Slowcost since 2000, speeduino since 2020, Caterha
posted on 11/7/16 at 09:17 PM Reply With Quote
My biggest (only) concern with that is the water running off the roof into the gap between the fence / side. It will get wet and have no way of drying out.
ste
posted on 11/7/16 at 10:00 PM Reply With Quote
will have a gutter at some point into a water butt
posted on 12/7/16 at 08:59 AM Reply With Quote
will have a gutter at some point into a water butt [/quot
From experience gutters and rainwater control are necessary. Wet wood rots quickly and the interior space can get wet too.
Rosco86
posted on 12/7/16 at 12:16 PM Reply With Quote
careful with the metal sheds as the condensation can be a nightmare!
My Build Thread
Volvorsport
posted on 22/7/16 at 05:22 PM Reply With Quote
Well. I answered my own question and bought 10 pallets from work for a fiver. 2.5m long 1.25 wide. We get them with full size stainless sheet for the laser machines
