Author: Subject: Compression Tester adapter
AlexXtreme
posted on 12/7/16 at 06:20 PM Reply With Quote
I am trying to check the compression on my silver top ford engine.... I have an only compression tester that worked fine for cross flows however for the zetec I realised i needed an extension adapter. Brought one from Machine Mart (down the road from me) but I can not get extension thread on the cylinder head... :-(. Feels like a stupid question but I am doing something wrong???
obfripper
posted on 12/7/16 at 06:58 PM Reply With Quote
The thread in a zetec spark plug hole does not start for the first 10mm and most adaptors only have 6mm of thread, if you are confident with your welding you could weld the adaptor to an old zetec spark plug body, and put an o ring in place of the seat gasket for a homebrew adaptor.
Dave
posted on 12/7/16 at 08:00 PM Reply With Quote
You need a long reach adpator (ie one with 14mm x 1.25 thread 3/4" (long )reach sparkplug thread) --- to give useable readings it should have the schrader valve at the point where it screws into the head.
No welding required.
A lot of ebay sellers incorrectly describe extra long extensions as long reach ---- spark plug reach is the length of the thread.
Similar to the plated extension screwed into the black adapter in this photo
Locost Running Compression
This kit has one
PETROL COMPRESSION TESTING KIT - CAR VAN MOTORBIKE CYLINDER HEAD TEST TESTER
Alternative buy the rubber cone type and get an assistant to crank the engine.
AlexXtreme
posted on 12/7/16 at 09:46 PM Reply With Quote
Hi thanks for this... looks like this is too short then
https://www.machinemart.co.uk/p/clarke-cht748-long-reach-compression-tester-ad/
that was a waste of £14!
Alex :-(
posted on 12/7/16 at 09:55 PM Reply With Quote
Alex :-(
That looks like 1/2" or 3/8" reach without a Schrathe lackder valve ------ apart from the thread reach being to short it will give false low readings.
because in effect it would lower the compression ratio.
benchmark51
posted on 12/7/16 at 10:37 PM Reply With Quote
I had that problem when using a Draper tester on my ST170. Fortunately I still had an AM- Tech tester, which never worked from new but had an assortment of adapters. Used the appropriate adapter with the Draper tester and ' BINGO' it worked.
It was this one
PETROL ENGINE AUTOMOTIVE COMPRESSION TESTER KIT DUAL SCALE GUAGE - TWO ADAPTORS
AlexXtreme
posted on 13/7/16 at 07:23 AM Reply With Quote
Thanks for the advice and new kit brought. The Machine Mart adaptor had the valve in but as you said, the reach is not long enough....
Alex
