Author: Subject: Exhaust routing question.
furryeggs
posted on 14/7/16 at 09:19 PM Reply With Quote
I have an St170 manifold that I'm modifying to fit my Avon. There is very little room to route it as the chassis members are right were the ST manifold needs to exit. If I route it backwards it only just misses the starter, so can anyone see a problem with my routing. It goes forwards and wraps back around the chassis bar, as there is very little room I've worked out the angles and pie cut, then tig'd the exhaust to get a tight enough bend.
[img][/img]
[img][/img]
[img][/img]
I don't fancy spending a few hundred quid for just a manifold from tiger, if this works ok my entire exhaust would have cost me £120 ( £25 manifold, £30 R1 silencer, £60 CAT, £5 1m 2.5" pipe).
ian locostzx9rc2
posted on 14/7/16 at 09:50 PM Reply With Quote
[img][/img]
[img][/img]
[img][/img]
ian locostzx9rc2
posted on 14/7/16 at 09:54 PM Reply With Quote
I think your pictures need reducing it looks like you have only got about 8-10mm clearance which is not enough as your be amazed how much your engine will move about your need a a min of 20mm I'm afraid or it will hit the chassis rails .
johnnybizzle1986
posted on 15/7/16 at 01:48 PM Reply With Quote
Nice work on the lobster back exhaust!, but there isn't much wiggle room, and the exhaust gasses wont like hitting the 90 degree T on the at the end of the front 2 header pipes, could restrict flow??.
Could you cut off the ST manifold further up? and put a collector or 2into1 facing down and a single swept bend coming out and down the car?
regards Jon
furryeggs
posted on 15/7/16 at 05:30 PM Reply With Quote
I will be cutting the st manifold higher to give more clearance, i've looked at some 2-1 sections but i'm strugling to find one that has measurements that will work.
A couple of youtube clips and a few bits of paper helped getting the bend about right, my self taught weldings and maths isn't up to making a complete 2-1 collector so i'll have to modify one.
