Author: Subject: Type 9 versus Mx5 5 speed gearbox
redscamp
posted on 23/7/16 at 11:51 AM Reply With Quote
I have driven the ford type 9 back to back with the five speed Mx5.
I found a day/night diffrence in the gear change in favour of the Mx5.
P100 & Mx5
https://flic.kr/p/JUdpsQ
posted on 23/7/16 at 12:20 PM Reply With Quote
If the type 9 was in the P100 I'm not surprised
chillis
posted on 23/7/16 at 12:32 PM Reply With Quote
the mx5 5 speed is a no brainer - lighter, stronger and closer ratios and of course much cheaper for a decent one than a type 9
Never under estimate the ingenuity of an idiot!
snapper
posted on 23/7/16 at 12:37 PM Reply With Quote
Show me the MX5 ratios
I eat to survive
I drink to forget
MikeR
posted on 23/7/16 at 08:02 PM Reply With Quote
How do you fit one to a xflow?
Luego.2.0
posted on 23/7/16 at 08:35 PM Reply With Quote
I have a type 9 on to a zetec black top. How easy would it be to change it to a mx5 one?
I used to have a few mx5s and still a member of the owners club. Got a gearbox in the shed never thought about swapping them😃
Veinto 2.0 black top.
Jenevy throttle bodies
Omex ecu
Luego.2.0
posted on 23/7/16 at 08:36 PM Reply With Quote
Omex ecu
Ugg10
posted on 23/7/16 at 09:13 PM Reply With Quote
http://www.miata.net/garage/KnowYourCar/S8_Gears.html
Mx5 - best one is - NB VERSION - 3.14, 1.89, 1.33, 1.0, 0.81
Not far off a long first type 9 with a better 5th overdrive.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
samjc
posted on 23/7/16 at 10:25 PM Reply With Quote
Im using an rx8 on a pinto due to strength as plan to run a duratec v6 eventualy so will use the same box just diffrent adapter plate.
Ugg10
posted on 23/7/16 at 11:01 PM Reply With Quote
Same here, about to put an rx8 6 speed box behind my 1.7 puma engine in my anglia. Guy on turbo sports (freddy686868) sell a few different adaptors. Just working out if I can retain the cable clutch. Don't think he had done a duratec v6 though, worth dropping him a line though to see.
[Edited on 23/7/16 by Ugg10]
