Author: Subject: Garage clearout - Sierra, P100 and R1 bits.
james h
posted on 26/7/16 at 08:36 PM Reply With Quote
I'm open to your best offers on all of the below. Feel free to u2u me or post below.
POSTAGE: I can post these items, but some are obviously a bit heavy and cumbersome. They will ship using 'ipostparcels' or any other method you suggest.
COLLECTION: You're welcome to collect the items from Wray, Lancashire. The village is 15 minutes from J36 of the M6.
Sierra rear hubs:
Rear hubs
Rear hubs
Sierra hub carriers:
I got these shot blasted, without specifying that the bearings should be sealed off. So you'll need new bearings (probably a good idea anyway!). I don't think the inside face is damaged.
Rear hub carriers
Rear hub carriers
Sierra front calipers
Steering racks
One of these is from a P100, the other from a Sierra - I don't think there is any difference between them. One doesn't have a pinion or seal (see photo). One of the pinions in the next listing can be included.
Racks
Racks
Racks 2
Racks 2
Pinions for rack
Pinions
Pinions
Sierra steering column upper
Column upper
Column upper
Steering link
Shortened, will need lengthening.
Steering link
Steering link
Sierra ignition assembly
Key, barrel, switch and horn contacts. As seen in the photo, part of the casting has broken. You might want to repair it, I haven't bothered yet!
Sierra ignition
Sierra ignition
P100 steering column
The wheel end of the column needs a nut, not a bolt like a standard Sierra column.
P100 column
P100 column
P100 column 3
P100 column 3
Sierra steering wheel
With horn centre. I don't know if the horn switch is working.
Wheel 1
Wheel 1
Wheel 2
Wheel 2
Upper column surround
The adjustable part has been cut off.
Upper column outer
Upper column outer
Unknown hub (P100?)
Unknown rear hub 2
Unknown rear hub 2
Unknown rear hub
Unknown rear hub
R1 (4XV/5JJ) airbox
Should fit 4XV and 5JJ.
airbox back
airbox back
Descriptionairbox front
MP3C
posted on 26/7/16 at 09:40 PM Reply With Quote
I remember getting one of those steering racks with you out of probably the most stripped down vehicle i have ever seen!!!! If you remember
Matt
