Author: Subject: Compomotive CXR's with Toyo R888 plus other stuff
Digger Barnes
posted on 27/7/16 at 01:36 PM Reply With Quote
OK,
I have had a dig a little deeper into the garage and I have another load of bits to get rid off, to get the ball rolling (more to follow later tonight).
I have a set of 4 compomotive CXR's 15x7 in anthracite ford 108mm x ET38 fittment. The R888's fitted all have about 4mm left on them so plenty of life left.
My car had a wishbone failure which resulted in me going up a verge. It took the paint off the rim on one of them over about 200mm and the paint on the back of the rim on the same wheel. One of the other wheels has a scratch on the rear. If it was me I would get the one wheel reconditioned and they would look perfect.
I used them for about 2000 miles from new.
Here is the picture of the front of them (another 12 pictures in my archive to show the condition and scratch(s))
They cost me over a grand with the tyres. They have got to be worth £450 even with the scratch, as R888 with 4mm are going on ebay for £200.
Anyway if you think that is too much make me an offer if you want them.
More to follow later
Wheels sold
[Edited on 29/7/16 by Digger Barnes]
Digger Barnes
posted on 27/7/16 at 06:51 PM Reply With Quote
Stainless steel braided fuel line 2.7m x 10-11mm bore nitrile plus a couple of short bits and fittings £20 posted.
Digger Barnes
posted on 27/7/16 at 06:54 PM Reply With Quote
Battery isolator £6.50 posted
Digger Barnes
posted on 27/7/16 at 06:59 PM Reply With Quote
Pair of master cylinders and reservoir £20 posted
Digger Barnes
posted on 27/7/16 at 07:02 PM Reply With Quote
4 bonnet catches, no hooks, however they are just a bit of bent metal with a couple of holes drilled in them. £15 posted.
Digger Barnes
posted on 27/7/16 at 07:05 PM Reply With Quote
Carbon fiber, motorcycle silencer. Straight through, noisy unit (sound great). It has a 10mm adapter plate that can be drilled and tapped for most bolt patterns. £55 posted
Digger Barnes
posted on 27/7/16 at 07:07 PM Reply With Quote
Mocal oil catch tank, these are £115 new, £55 posted (obo).
Digger Barnes
posted on 27/7/16 at 07:09 PM Reply With Quote
Alloy radiator header tank (could do with a polish), I guess this must be a custom made unit. £25 posted.
Digger Barnes
posted on 27/7/16 at 07:11 PM Reply With Quote
Pile of samco hoses, 6mm, 9mm, 11mm, 16mm, 32mm would suit a bec build. Got to be worth £25 posted.
Sold
[Edited on 28/7/16 by Digger Barnes]
Digger Barnes
posted on 27/7/16 at 07:16 PM Reply With Quote
MK indy rear uprights, grooved solid disks, ford calipers (done about 4 - 5K). There is surface rust on the disks, which will vanish when used. There is a crack in the powder coat on one of the uprights that leads me to believe that it could do with a bead of weld putting down (second picture). Not sure what they are worth, but got to be about £130 posted.
Digger Barnes
posted on 28/7/16 at 05:49 PM Reply With Quote
Samco Hoses Sold
Digger Barnes
posted on 29/7/16 at 09:28 AM Reply With Quote
Wheels sold
Digger Barnes
posted on 29/7/16 at 10:16 PM Reply With Quote
Mocal oil catch tank sold
Digger Barnes
posted on 1/8/16 at 07:52 AM Reply With Quote
Radiator header tank sold
Rear uprights sold
Master cylinders sold
