Author: Subject: Heat management
ian996
posted on 27/7/16 at 09:51 PM Reply With Quote
Heat management
I was overcooling a wee bit on the westy so took off the oil to air cooler and fitted a cossie modine. That was Feb.
I got back to UK, took it out (was hot) and it was getting a bit hot - 95/100.
So i refitted the oil to air and on a cool night its a bit cool - 75/80.
Setup is a davies craig water pump, 2 row polo alloy rad. no heater on a 270hp duratec.
Any ideas on what is best? im thinking back to modine and a 3 core rad - but before i throw cash at it - thought id ask.
40inches
posted on 27/7/16 at 10:00 PM Reply With Quote
Do you have an oil stat in the feed hose to the cooler?
bi22le
posted on 27/7/16 at 10:11 PM Reply With Quote
Cover up a section of the rad?
Please read my ring story:
coyoteboy
posted on 27/7/16 at 10:33 PM Reply With Quote
This would be my first simple change before removing stuff.
posted on 28/7/16 at 05:40 AM Reply With Quote
Oil Stat --- really essential with an oil cooler
big-vee-twin
posted on 28/7/16 at 12:50 PM Reply With Quote
95/100 is normal for a Duratec.
http://www.triangleltd.com
40inches
posted on 28/7/16 at 03:08 PM Reply With Quote
Yep, the Jag engine runs at this temp range, along with most modern engines.
