Author: Subject: Gulf MNR Vortx R1
Digimon
posted on 30/7/16 at 04:59 PM Reply With Quote
Gulf MNR Vortx R1
Hi Guys,
I'm putting my MNR Vortx up for sale because i'm looking to do some competitive motorsport, I'm looking in to Time Attack at the FWD Club Challenge classe.
I'm not in a massive rush to sell the car and if it doesn't sell I will continue with trackdays for now. I'm looking for £9500 ovno
The car is located in Deal, Kent
My forum post on what I have done with the car
http://www.locostbuilders.co.uk/forum/40/viewthread.php?tid=181937& amp;page=1
Most of the spec, im sure ive missed something
MOT'ed until 17th June 2017
Full rose jointed chassis with inboard front suspension
2000 Yamaha R1 engine
Shortened Escort quick rack
Protech Shocks
Ford Cortina front calipers with solid discs
Ford Sierra rear calipers with solid discs, modified for 13” wheels using smaller handbrake springs
Caterham R500 wheels – 6J fronts, 8J rears
Ford Sierra Cosworth diff with LSD
MNR exhaust manifold and system
MNR BIAS pedal box
Remote BIAS adjuster
New Wilwood master cylinders
Racetech mirrors
GRP Seats. Front seat is on rails, passenger seat is fixed and half height
One off rollcage
Carbon Fibre front and rear lights
Rapid-Shift Quickshifter, flat up shifts only
AB Performance paddle shift (BTCC style lever or you can refit the paddles)
AB Performance Baffle Plate
Ralloy Oil catch tank
Pipercross PX600 Air Filter
KOSO RX2+ digi dash
Stack Water temp gauge
Stack Oil temp gauge
Stack Oil pressure gauge
Stack Volt gauge
VDO dip fuel sender
Schroth 3” 6 point drivers harness
Schroth 3” 4 point passenger harness
Nord-Lock diff washers
M16 caliper seal kit
M16 caliper stainless steel locking tabs
2 x new Quinton Hazell wheel bearings
2 x new track rod ends
2 x new steel steering rack extensions
Ferodo DS2500 front pads
EBC Ultimax rear pads
PitKing Products Volcano Exhaust Wrap 100ft
C43 Oil to Water Laminova cooler, Medium equivalent to a 16 row
Torques Universal Oil Sandwich Plate with AN-08 fittings and Take Off Cover with M20x1.5
2 x Straight AN-8 oil fittings
2 x 90 Degree AN-08 fittings
1/2 Meter of AN-08 oil hose
M20x1.5 joining bolt
Rear Alloy Diffuser
Rally Design steering wheel with quick release hub
Coolexperts aluminium radiator
Engine oil has been changed every 6 months with Silkolene Comp 4 10w-40 and a new Hi Flo filter each time. The car is fully setup and corner weighted for an 85kg driver, the car weighs in at 480kg with half tank of fuel.
The only real bad point with his car is the bonnet. The standard bonnet clips failed and the bonnet has been damaged where it hit the floor, I’ve been told a replacement is £145
I have some carbon fiber front wings and I also have 4L Silkolene oil and other spares what will go with the car if I get the full asking price
daveb666
posted on 30/7/16 at 07:42 PM Reply With Quote
Stunning car.
Good luck with the sale.
View User's Profile Visit User's Homepage View All Posts By User U2U Member   daveb666 's Aim
Digimon
posted on 31/7/16 at 05:19 PM Reply With Quote
Thanks Dave
