New Topic New Reply
Author: Subject: Just starting out
Dirtyderv
posted on 31/7/16 at 01:16 PM Reply With Quote
Just starting out
Hi there going to be building a locost bought a part built chassis from eBay very cheap, I'm leaning towards it's a Ron champion spec book build, I've got a Haynes book, but looks like I'm needing the earlier book as well, I've also got a e46 325i that's rotten which is going to be a base for the running gear, can anyone identify my chassis and are my plans feasibly with this chassis, cheers jay
[img]http://s1222.photobucket.com/user/gsiwannabe/media/Mobile%20Uploads/image_3.jpeg.html?filters[user]=111204395&filters[recent]=1&sort=1&am p;o=1[/img]
[img]http://s1222.photobucket.com/user/gsiwannabe/media/Mobile%20Uploads/image_4.jpeg.html?filters[user]=111204395&filters[recent]=1&sort=1&am p;o=0[/img]
[img]http://s1222.photobucket.com/user/gsiwannabe/media/Mobile%20Uploads/image_1.jpeg.html?filters[user]=111204395&filters[recent]=1&sort=1&am p;o=3[/img]
Slimy38
posted on 31/7/16 at 02:10 PM Reply With Quote
Not sure about the chassis, but I have to be brutally honest and say that I'd never consider putting that engine in a Ron Champion design. His design was based very much around the 1300 or 1600 engines available in the donor car, and there are posts on here that suggests anything bigger will overwhelm it.
That is just my opinion though, I have no documented evidence.
Ben_Copeland
posted on 31/7/16 at 02:36 PM Reply With Quote
Dave666 has about 300bhp in a Locost chassis so id say they are quite capable of running whatever you want too.
The earlier chassis was built around mk1/2 escort parts with solid rear axle.
The Haynes chassis is based on Sierra/mx5/bmw options so might be better to build the Haynes roadster as it's designed for independent rear suspension.
But either chassis are quiet capable!!!
My Haynes chassis has no problem with 272bhp/309ftlb and is getting a power increase later in the year. (100bhp+)
Ben
Locost Map on Google Maps
Enter Your Details Here
gremlin1234
posted on 31/7/16 at 07:41 PM Reply With Quote
you also must have the iva manual, which details minimum build standards to work with.
the mot manual can be very helpful too
axle
posted on 10/8/16 at 07:10 AM Reply With Quote
There were a few discrepancies even with the old book, better see Haynes forum as well.
Regards Axle
IVA passed 1st time thanks to the Forum members.
Dirtyderv
posted on 17/8/16 at 06:30 PM Reply With Quote
Thanks for all the inputs guys, slowly getting some parts together, and will be stripping my e46 this weekend
craigdiver
posted on 7/9/16 at 08:54 PM Reply With Quote
I'm currently building a McSorley 442E chassis (similiar to locost chassis but longer/wider/taller - google it, plans are freely available). The 442E is designed for solid rear axle so I'm modifying the design to make it a haynes roadster rear end so I can use BMW diff and IRS. My donor was a 5 series BMW with the 2.5 6-cylinder double vanos engine. Was hoping to use the BMW hubs but I found the suspension setup far too complex (and heavy). Instead I have opted for the easy option and picked up front and rear sierra hubs and driveshafts that I will somehow graft onto the BMW driveshafts attached to the BMW diff.
The engine is quite tall even though it is partially on its side, may have issues height wise with the standard locost chassis - although it has been done.
Good luck, BMW 6-cylinder locost will be awesome. (My build is in the build diary section)
If it ain't broken, fix it anyway (just because).
Building - BMW powered Haynes Roadster/442E hybrid.
Volvo C30 T5 Polestar
craigdiver
posted on 7/9/16 at 08:56 PM Reply With Quote
Have fun stripping the BMW, I couldn't believe how much wiring loom and $#!t they squeeze into their cars!
New Topic New Reply
