I have an old style fuse box in the garage which I want to replace the fuses (by domino style I mean the big bulky things with spots on to identify
lighting/power etc with white red or blue spots) with circuit breakers, so I can isolate a circuit without having to pull a fuse. They are a blade
type fitting which slide in & out of the front of the panel
What is the correct name/type for what I need to fit, there seem to be loads of different types - MCB, Wylex, Mini, Type B etc etc, I don't want
to buy something that won't fit!
So are the important words Wylex & MCB for standard consumer units? I assume the type B curve is referring to the way the circuit breaker will
define when it should break the current?
Sorry can't help you any further. I remember looking into this several years ago and this was the type I needed to replace the fuse wire type
in my consumer unit. If you go to B&Q they have these and others with information on the package which may help.
If you go into an electrical wholesalers and ask for plug-in mcbs to replace rewireable fuses, you'll get the right thing. B-type does indeed
relate to how it trips.
It would be a better installation though if you had an rcd somewhere.
