Author: Subject: 7 sized carb engine loom
mongrelwestie
posted on 3/8/16 at 10:07 PM Reply With Quote
Where's a good spot to get a full car loom?
axle
posted on 4/8/16 at 01:56 PM Reply With Quote
Modify the original from the Donner it can save a lot of time trying to adopt it to your car using the original wiring diagram it keeps the cost down too.
Regards Axle
IVA passed 1st time thanks to the Forum members.
mongrelwestie
posted on 4/8/16 at 02:15 PM Reply With Quote
I'm anal! I want a nice clean new simple loom, I'm not running wipers, washers and heaters etc so just simple stuff
axle
posted on 4/8/16 at 07:57 PM Reply With Quote
Okay try
http://www.autosparks.co.uk/
I hope they can help
Regards Axle
hkp57
posted on 5/8/16 at 06:35 AM Reply With Quote
http://www.rapidfitlooms.co.uk/7stylewiringloom.htm
http://www.elitemotorsport.co.uk/budget-car-wiring-loom-77-p.asp
http://www.bodylogicuk.com/index.php/5/512522/
Fleet
SKC Raptor R - Hayabusa
Toyota C-HR Hybrid Limited Edition
Honda VFR1200 CrossTourer
DCT
Marlin Roadster 1800
Mercedes Vito 116 Sport
snowy2
posted on 6/8/16 at 06:35 AM Reply With Quote
make one.......
i have just rewired my car (including the engine ecu....) the cars electrics with all the switches and relays (15 relays and 20 fuses in total) only took a weekend.....mind you i have done it a few times.
but rewiring a car is VERY EASY.........
there is an article on this forum showing you how.
sometimes you are the pigeon, most of the time the statue.
axle
posted on 6/8/16 at 07:54 AM Reply With Quote
any idea where this article would be I like to improve my wiring skills?
Originally posted by snowy2
make one.......
Regards Axle
snowy2
posted on 6/8/16 at 10:04 AM Reply With Quote
Brought it to the top of the list for you......dave
axle
posted on 6/8/16 at 06:54 PM Reply With Quote
Hi Dave
Sorry for being a bit thick I do not see it , thanks for your help it is not magazine ad on the main page?
Regards Axle
snowy2
posted on 6/8/16 at 08:38 PM Reply With Quote
It's called "how to wire your car" it the post u der or above this one....
axle
posted on 7/8/16 at 08:10 AM Reply With Quote
cheers Dave tremendous help
[Edited on 7/8/16 by axle]
Regards Axle
snowy2
posted on 7/8/16 at 11:54 AM Reply With Quote
No problems......you don't have to use connectors the way I have shown you but it's a tried and tested system .......worked on several cars with out issues....
