Author: Subject: Hayabusa starter clutch
thurso
posted on 8/8/16 at 08:11 PM Reply With Quote
looking for a starter clutch/sprag clutch, needs to be the fully splined version
thnx
phelpsa
posted on 8/8/16 at 09:06 PM Reply With Quote
Sprag clutch or torque limiting clutch (upper or lower)?
thurso
posted on 8/8/16 at 09:16 PM Reply With Quote
Sprag clutch , also know as starter clutch
phelpsa
posted on 8/8/16 at 09:34 PM Reply With Quote
You may well already know this but post 2002 Busas have two starter clutches. The upper one is sometimes referred to as a sprag clutch but isn't. If it is the sprag clutch you want (located on the end of the crank) they are difficult to find used but are available from Robinson foundry new for about £130.
thurso
posted on 8/8/16 at 09:41 PM Reply With Quote
hi yes its the sprag on the crank
thanks for info
