Author: Subject: Zetec turbo engine
CRAIGR
Contributor
Posts 2750
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 9/8/16 at 04:56 PM Reply With Quote
Zetec turbo engine
Testing the water to see what's about.
Ideally looking for a 2ltr zetec turbo engine with or without ancillaries
Please pm me if you know of anything
posted on 9/8/16 at 07:37 PM Reply With Quote
There was one on the zetecrwd Facebook page not too long ago....
jossey
posted on 10/8/16 at 05:05 PM Reply With Quote
Don't do it.
I got mine done zetec turbo. 267 at the wheels and since then I've had to upgrade the following so I don't die
Roll cage
Brakes £1200
New suspension
New wider wheels
New prop
New diff
New half shafts
David Johnson
posted on 10/8/16 at 05:33 PM Reply With Quote
What spec David???
jossey
posted on 10/8/16 at 09:27 PM Reply With Quote
We spoke a while back about it when I first got it.
Engine is a Ford Mondeo zetec E bottom end fitted with forged pistons, HD bearings, new HP oil pump, new water pump. The head is a new (not recon) Focus blacktop fitted with Piper performance valve springs.
Raceline sump
The induction is a custom made system based on a Jenvey inlet manifold, large plenum with large throttle body. 625cc Siemans Daka injectors.
Bailey dump valve.
Custom charge cooler with own separate water system, radiators mounted in front of engine radiator, separate water pump (Focus RS) and header tank.
Turbo is a Subaru Impreza TD04L on a Focus exhaust manifold, custom exhaust system, currently running 18PSI of boost.
Engine management is MS2, with boost control, MSD coilpack and leads. Launch control via dash mounted switch.
Fuel system is new Bosch 044 GRP A cosworth pump, large fuel filter, Lucas fuel pressure regulator.
David Johnson
posted on 10/8/16 at 10:53 PM Reply With Quote
That sounds good, should be good for 400 bhp????
jossey
posted on 11/8/16 at 06:35 AM Reply With Quote
Ye If I change the turbo. It's running 14 psi at present so this one should do 300 will probably change for the Volvo t5 turbo engine
Before
After
[Edited on 11/8/16 by jossey]
David Johnson
posted on 11/8/16 at 09:18 AM Reply With Quote
Yes, yes and yes
hazardpro
posted on 1/12/16 at 05:00 PM Reply With Quote
no intercooler?
