craig_thomas
posted on 10/8/16 at 05:14 PM |
MK Indy scuttle diamensions
Could anyone tell me the width/height/length of the MK Indy scuttle/bonnet and nose cone please.
40inches
posted on 10/8/16 at 06:30 PM |
I can get those for you tomorrow, if no one else comes forward in the mean time.
craig_thomas
posted on 10/8/16 at 06:43 PM |
Cheers mate
40inches
posted on 11/8/16 at 11:09 AM |
Dash side of Scuttle width 107cm
Scuttle length 34cm
Scuttle height, engine side 27cm
Bonnet length 87cm
Nose cone, at bonnet fitting point 66cm wide x 20cm high
Nose cone length 60cm
The Scuttle is fitted with the back edge in line with the intersection of the parallel side rails, and the tapered side rails.
From the back of the Scuttle to the end of the step in the nose cone is 152cm i:e the length of the chassis rail.
On mine there is a 40mm gap between the end of chassis rail and the drop in the nose cone.
craig_thomas
posted on 11/8/16 at 01:13 PM |
Scuttle length 34cm
Bonnet length 87cm
Thanks a lot this is a great help, do you have the engine side scuttle width and scuttle depth?
40inches
posted on 12/8/16 at 12:49 PM |
Scuttle length 34cm
Bonnet length 87cm
Width 95cm
front to back on centre line25cm
height on centre line 27cm
